Generating 3-phase sine wave..
Results 1 to 39 of 39
    More information than you can shake a stick at here...doesn't delve too much into the 3 phase aspect though...
    http://www.picbasic.co.uk/forum/show...light=inverter
    Italy
    Hi Sylvio,
    (Somehow related).
    Speed Control of 3-Phase Induction Motor Using PIC18 Microcontrollers
    Microchip AN843: (PDF)
    http://ww1.microchip.com/downloads/e...tes/00843a.pdf
    (Code and PDF).
    http://www.microchip.com/stellent/id...pnote=en012011
    Example of 3-phase bridge driver chip:
    http://www.irf.com/product-info/data...ata/ir2136.pdf
    Best regards,
    Luciano
    Jan 2007
    Brazil
    Smile
    Well.. Thank you Skimask and Luciano. Excelent readings!
    So, I've bought a 16F777 and it has 3 CCP modules. As suggest in the readings above, it becomes easier to create an analog output when using high PWM frequencys. Using @ 20Mhz and Mister_E's PicMultiCalc, it turn out that it can generate frequencys > 20Khz, what is enought to this application.
    Timer2 is responsable to control the PWM frequencys (all the same).
    Timer1 is responsable to create the interruption to supply the new duty cycle value.
    Now, let'ss think about the sine table and the software. Just to remember, I'll create an interface to control sine frequency, amplitude and also the sine table, as it would be interesting to create harmonics, sags and swells.
    The sine table could be in the pic's data memory or it could be sent throught USART everytime that the user changes the interface option, like frequency. Do you think that it would work in real time using USART?
    Thanks again!
    Sylvio,
    Jan 2007
    Brazil
    Well, things have been working until now...
    When Timer1 interrupts, a INDEX var is summed and another position in a sine table is selected.. then a new value is output throught HPWM.
    The sine table is filled with 72 number.. So, to create a 60Hz sine wave, o must read it at approx. 4.32KHz.
    So, When I set timer1 to 64386 (1:1 prescaler @ 20MHz), it should interrupt at ~4.32KHz and create de 60Hz sine wave... but, it is generating a 26Hz... if I set timer1 to 65000, it decreases the 26Hz to 20Hz ... I didnt get iT! It should read the table faster, shoul'nt it?
    Well, thanks!!!
    Sylvio,
    Quote Originally Posted by sirvo View Post
    I'm guessing here, wild stab, since I don't see any other code here...
    It might be reading it faster, but it might be missing/skipping a Tmr1 interrupt due to how long it takes to accomplish your interrupt code.
    Try increasing the number by small amounts, see if it actually increases up to a point, and then drops off.
    Jan 2007
    Brazil
    So, here we go..
    Didnt show var byte stuffs..
    define  OSC 20
    DEFINE HSER_SPBRG 10  ' 115200 Baud @ 20MHz, -1,36%
    ' Set CCPx pins to outputs
    TRISC.2 = 0 ' CCP1 output
    TRISC.1 = 0 ' CCP2 output (could also be assigned to RB3)
    TRISB.5 = 0 ' CCP3 output
    ' Set CCP modules to PWM mode
    CCP1CON = %00001100 ' Mode select = PWM
    CCP2CON = %00001100 ' Mode select = PWM
    CCP3CON = %00001100 ' Mode select = PWM
    INTCON = %11000000
    LOAD = 64386' 4320Hz
    'LOAD = 0
    TMR1H = LOAD.HIGHBYTE
    TMR1L = LOAD.LOWBYTE
    T1CON = %00000001
    PIE1.0 = 1
    PR2 = 49
    PORTD.0 = 0
    ' Set TMR2 up for 1:1 prescale & turn it on
    T2CON = %00000100 ' TMR2 ON 1:1 prescale
    INT_LIST macro ;IntSource, Label,    Type, ResetFlag?
        INT_Handler TMR1_INT, _Timer1,   PBP, yes
    @    INT_ENABLE  TMR1_INT   ; Habilita interrupção do TMR1
    MAIN:
        IF FLAG = 1 THEN
            flag = 0
            CONTA = CONTA + 1
            CONTB = CONTB + 1
            CONTC = CONTC + 1
            if contA = 71 then contA = 0
            if contB = 71 then contB = 0
            if contC = 71 then contC = 0
            index  = conta
            GOSUB tabela
            va = v
            index  = contB
            GOSUB tabela
            vb = v
            index  = contC
            GOSUB tabela
            vc = v
            GOSUB SAIDA
        GOTO MAIN
    TABELA:
        SELECT CASE DIST
        CASE 1: ' Fundamental
               LOOKUP INDEX, [100,109,118,126,135,143,151,158,165,171,177,183,187,191,195,197,199,200,200,199,198,196,193,189,185,180,175,168,162,154,147,139,130,122,113,104,96,87,78,70,61,53,46,38,32,25,20,15,11,7,4,2,1,0,0,1,3,5,9,13,17,23,29,35,42,49,57,65,74,82,91], V
        CASE 2: ' 3 com 20%
               LOOKUP INDEX, [100,114,127,140,152,162,170,177,182,185,187,187,187,185,184,182,181,180,180,180,181,182,184,185,187,187,187,185,182,177,170,162,152,140,127,114,100,86,73,60,48,38,30,23,18,15,13,13,13,15,16,18,19,20,20,20,19,18,16,15,13,13,13,15,18,23,30,38,48,60,73,86], v
        CASE 3: ' 3 com 20% + 5 com 10%
               LOOKUP INDEX, [100,118,135,150,161,170,175,178,178,178,177,177,178,180,182,185,188,189,190,189,188,185,182,180,178,177,177,178,178,178,175,170,161,150,135,118,100,82,65,50,39,30,25,22,22,22,23,23,22,20,18,15,12,11,10,11,12,15,18,20,22,23,23,22,22,22,25,30,39,50,65,82], V
        CASE 4: ' 3 com 20% + 5 com 10% + 7 com 10%
               LOOKUP INDEX, [100,124,144,159,168,171,170,168,168,171,175,181,187,190,190,188,184,181,180,181,184,188,190,190,187,181,175,171,168,168,170,171,168,159,144,124,100,76,56,41,32,29,30,32,32,29,25,19,13,10,10,12,16,19,20,19,16,12,10,10,13,19,25,29,32,32,30,29,32,41,56,76], V
        CASE 5: ' 5 com 10% + 7 com 20%
               lookup index, [100,122,139,149,151,147,141,136,137,145,157,172,186,194,197,194,188,183,181,183,188,194,197,194,186,172,157,145,137,136,141,147,151,149,139,122,100,78,61,51,49,53,60,64,63,55,43,28,14,6,3,6,12,17,19,17,12,6,3,6,14,28,43,55,63,64,59,53,49,51,61,78], v
        CASE 6:
        CASE 7:
        end select
    SAIDA:
            CCP1CON.4 = VA.0
            CCP1CON.5 = VA.1
            CCPR1L = VA >> 2
            CCP2CON.4 = VB.0
            CCP2CON.5 = VB.1
            CCPR2L = VB >> 2
            CCP3CON.4 = VC.0
            CCP3CON.5 = VC.1
            CCPR3L = VC >> 2
    Timer1:
        TMR1H = load.highbyte
        TMR1L = load.lowbyte
        FLAG = 1
    @ INT_RETURN
    Sylvio,
    Do(does?) DT_INT's reset TMR1IF for you?
    Past that, get rid of everything else and just toggle a pin, only toggle a pin, and nothing but toggle a pin...and measure that and see what happens.
    What does this do on PortD.0?
    define  OSC 20
    TRISC.2=0 : TRISC.1=0 : TRISB.5=0 : TRISD.0 = 0 : CCP1CON=12 : CCP2CON=12
    CCP3CON=12 : INTCON=$c0 : LOAD=64386 : TMR1H=LOAD.HIGHBYTE
    TMR1L=LOAD.LOWBYTE : T1CON=1 : PIE1.0 = 1 : PR2 = 49 : PORTD.0 = 0 : T2CON = 4
    MAIN: GOTO MAIN
    Timer1: TMR1H = load.highbyte : TMR1L = load.lowbyte
         if portd.0 = 0 then
              portd.0 = 1
              portd.0 = 0
    @ INT_RETURN
    My point is that it looks like your program 'flow' is jacked up and needs to be reworked.
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 13:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 03:31
  3. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 07:54
  4. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 14:19
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 07:35
