Generating 3-phase sine wave..
Results 1 to 39 of 39
    Quote Originally Posted by sirvo View Post
    Yes, it DO (does) reset...
    I set portd.0 to toggle on timer1 interrupt and it's been working fine.. (4.2Khz)..(i didnt get rid of those stuffs)
    Then I set portd.0 to toggle inside the (if Flag = 1 then...) and it's been toggling in a frequency of 900Hz... It should be also 4Khz....
    Well, any idea?
    Thanks!
    Are those GOSUBs and LOOKUPs still inside the Flag=1 If/Then block?
    Jan 2007
    Brazil
    I've measured the frequency of the block (if flag = 1 then) with and without the GOSUB/LOOKUP table.. it remains still ~900Hz...
    I was thinking about the HPWM frequency generated by Timer2.. Its frequency is ~100Khz ..
    Should not it be the problem? Well, I changed it to 20Khz and still got 900Hz...
    Thanks...
    Sylvio,
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  3. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  4. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 15:19
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
