Generating 3-phase sine wave..
Results 1 to 39 of 39
    Do(does?) DT_INT's reset TMR1IF for you?
    Past that, get rid of everything else and just toggle a pin, only toggle a pin, and nothing but toggle a pin...and measure that and see what happens.
    Jan 2007
    Brazil
    Yes, it DO (does) reset...
    I set portd.0 to toggle on timer1 interrupt and it's been working fine.. (4.2Khz)..(i didnt get rid of those stuffs)
    Then I set portd.0 to toggle inside the (if Flag = 1 then...) and it's been toggling in a frequency of 900Hz... It should be also 4Khz....
    Well, any idea?
    Thanks!
    Sylvio,
    Quote Originally Posted by sirvo View Post
    Well, any idea?
    Thanks!
    Are those GOSUBs and LOOKUPs still inside the Flag=1 If/Then block?
    Jan 2007
    Brazil
    I've measured the frequency of the block (if flag = 1 then) with and without the GOSUB/LOOKUP table.. it remains still ~900Hz...
    I was thinking about the HPWM frequency generated by Timer2.. Its frequency is ~100Khz ..
    Should not it be the problem? Well, I changed it to 20Khz and still got 900Hz...
    Thanks...
    Sylvio,
  1. To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2014, 14:39
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  3. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  4. 3 phase PWM with dsPIC30F2020
    By nemmard in forum mel PIC BASIC
    Last Post: - 21st January 2009, 15:19
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
