How to program PIC16F877A stepper motor revolution [Full circuit & 3/4 Code]
Results 1 to 12 of 12
    Nov 2008
    Smile How to program PIC16F877A stepper motor revolution [Full circuit & 3/4 Code]
    Automatic Blind System
    Hi there,
    I'm currently working on project call automatic blind system which is activate depends on outside condition. Before this is tried to build this project MICROCONTROLLER BASED AUTOMATED LIGHT CONTROL SYSTEM which is based on AVR ATMEGA32 but it failed to get what is has supposed to..
    Since that i try to switch to PIC and found out using PBP is time saving and cost reduced language since the project submission is just around the corner..I hope PBP master here can fix my code since i wrote this just a day ago with zero knowledge of PBP by just reviewing the manual and project book. Here is the circuit diagram and code. The proteus VSM files will be PM if someone really want to help.
    The Circuit
    PicBasic Pro code
    '*  Name    : 877A_BLIND.BAS                                    *
    '*  Author  : PIJO RAHMAN                                       *
    '*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/4/2008                                         *
    '*  Notes   : Using PIC16F877A to control Vertical Blind Auto   *
    '*            and Manual with light sensor                      *
    CMCON = 7
    ADCON1 = 7
    TRISB = 0 ' Set PortB as output
    TRISA = 1 ' Or TRISA = 255, set PortA as input
    Define  LCD_DREG        PORTD 'Based on Rentron 877A LCD Connection
    Define  LCD_DBIT        4
    Define  LCD_RSREG       PORTE
    Define  LCD_RSBIT       0
    Define  LCD_EREG        PORTE
    Define  LCD_EBIT        1
    B1 VAR BYTE            'Declared Byte For LCD Splash Screen
    B0 VAR BYTE
    B2 VAR BYTE
    B3 VAR BYTE
    B4 VAR BYTE
    B5 VAR BYTE
    clear                   'clear all variables
    LCDOUT $FE,1            'clear lcd
    PAUSE 500               'pause for lcd init
    Low PORTE.2             'LCD R/W line low (W)
    '*****************slide text for splash screen**************************
    LOOP:
    LCDOut $fe,2
    For B2= 0 TO 15
    LookUp B0, ["               AUTOMATIC BLIND SYSTEM              #"], B1
    IF B1 = "#" Then GoTo reset
    LCDOut B1
    B0 = B0 + 1
    Next B2
    pause 125        'character wait time
    B0 = B0 - 15
    GoTo loop
    RESET:
    LCDOUT $FE,1
    CREDIT:                     'Display Presenter Credit
      LCDOUT $FE,$80
      LCDOUT "PRESENTER NAME"  'presenter  credit
      'LCDOUT $FE,$C0
      'LCDOUT " GROUP   "   'presenter  credit
      PAUSE 1500
      LCDOUT $FE,1
    speed var word
    speed = 100
    ;i var byte
    Main:                   ' Main Prgm, Check Button for Auto/Manual Op
    IF PORTA.0=1 THEN Manual
    If PORTA.1=1 Then ForwardM
    If PORTA.1=0 Then ReversesM
    Goto Main
    Manual:     'FOR MANUAL OPERATION START WITH RA0=1 THEN CONTROL RA2 AND RA3
    Pause 500    'Do it about 2 times a second
    LCDOUT $FE,1  'Clear LCD
    LCDOUT $FE,$80,"MANUAL"   'Display "Manual" 1st Line on LCD
    LCDOUT $FE,$C0,"USER INPUT" 'Display "USER INPUT" 2nd Line on LCD
    IF PORTA.2=1 THEN FORWARDM   'Manually Opening Blind
    IF PORTA.3=1 Then ReversesM   'Manually Closing Blind
    Goto Main
    ForwardM:
    LCDOUT $FE,1
    LCDOUT $FE,$80,"OPENING BLIND"
    LCDOUT $FE,$C0,"DAYLIGHT"
    ;FOR i = 1 TO 5 ' one revolution   'Actually Use this Function for Revolution Step But No LUCK! :(
    GOto Forward ' rotate clockwise
    ;NEXT i
    GOTO Main
    ReversesM:
    LCDOUT $FE,$80,"CLOSING BLIND"
    LCDOUT $FE,$C0,"SUNSET/DARK"
    Goto Reverses ' rotate counter-clockwise
    ;NEXT i
    GOTO Main
    Forward:     'Stepper Motor Clockwise Sequence
    portb = %1100
    pause speed
    portb = %0110
    pause speed
    portb = %0011
    pause speed
    portb = %1001
    pause speed
    Goto Main
    Reverses:        'Stepper Motor AntiClockwise Sequence
    portb = %1001
    pause speed
    portb = %0011
    pause speed
    portb = %0110
    pause speed
    portb = %1100
    pause speed
    Goto Main
    The operation
    This project is simple as it shows. The circuit is consist of manual and automatic function. SW1 connected at RA0 is to use to switch between auto/manual mode. In auto mode, all the manual control switch which is SW3 and SW4 is not activated but only receive the signal from SW2 [which is will be interface to light-dark activated switch, so no ADC will be required]. If SW2 high, motor is rotate clockwise and the blind is open, but if SW2 low, motor is rotate anticlockwise and the blind is close.It need 10 stepper motor revolution [according to my blind] to open and close the blind slat, which is i dunno how to program it. ... so even the switch is still in high, the stepper only rotate 10 times and stop and wait till the other state. The stepper motor that I use is common 1.8 degree per step.
    The operation repeated until someone invoke the manual switch.
    Other switch which is SW5-SW6 is to use to control blind vertical position by using simple DC motor interface to L293D which is will be added later on. The LCD 16x2 is only to display operations, since PIC16F877A still have the unused port.
    p/s: If someone interested in this project or feel free to help, just pm me to get the proteus VSM files. Since the dateline is only a week, I hope someone can help me urgently..Thanks in advance!
    I am most likely missing something, but what about this
    ForwardM:
    LCDOUT $FE,1
    FOR i = 1 TO 500 ' ?? will equal 10 revolutions ??
    portb = %1100
    pause speed
    portb = %0110
    pause speed
    portb = %0011
    pause speed
    portb = %1001
    pause speed
    NEXT i
    GOTO Main
    Unless you are counting steps (and have limits preset), I see no way of detecting end of travel of your blind, which means you can drive it beyond it's stop position in either open or close mode.
    Nov 2008
    ForwardM:
    LCDOUT $FE,1
    portb = %1100
    pause speed
    portb = %0110
    pause speed
    portb = %0011
    pause speed
    portb = %1001
    pause speed
    NEXT i
    GOTO Main
    I tried this code but the motor also seems to rotate without stop.
    I thought it's possible to count the motor step (limit the step). Is there anyway to achieve this?
    I've thinking again, how about use the inside sensor, double the sensor to set the stop position. When the blind is open and the 2nd sensor which is located in the room detect the light, it will stop the motor. This is meant the 1st sensor use to start the motor and 2nd sensor use to stop the motor.
    Same thing goes to close operation. if the outside = 0 and the inside = 0 the blind will close.
    to summary this,
    open operation:
    1st sensor = 1 (motor start) then 2nd sensor = 1 (motor stop)
    close operation:
    1st sensor = 0 (motor start) then 2nd sensor = 0 (motor stop)
    My question is, how can i use any label that prevent the motor spinning like the stop/pause function?
    Quote Originally Posted by slapdash View Post
    I forgot to say i needs to be a word size variable, as a byte it can never reach 500
    If you do not have a preset limit like Melanie mentioned you can make the stepper stop, but it may not always stop in the exact same place. If there is some drag on the mechanism for example.
    You could use a light sensor, but what if there is enough light to start but not stop. Or attach a couple of micro limit switched that a hit on full open or full close. There are many ways to make some sort of encoder. If the blind are only rotating 90 degrees a pot fixed to a blade may work.
    Really ??? Everyone have it's own project
  1. PIC 16F877A circuit for stepper motor...
    By kristina in forum mel PIC BASIC Pro
    Last Post: - 27th June 2012, 09:13
