A simple and basic question
Results 1 to 36 of 36
    Ted's's Avatar
    Ted's Guest
    skimask, happy birthday.
    I created a new code:
    Zahl VAR WORD
    DEFINE OSC 20
    WHILE Zahl < 60000
        Zahl = Zahl + 1
    WEND
    There was no lst created but a mac, asm and hex.
    mac:
    	NOLIST
    LABEL?L macro Label
            RST?RP
        ifdef PM_USED
            LALL
    Label
            XALL
    Label
    ADD?WCW macro Win, Cin, Wout
        if (Wout == Win)
          if (Cin == 1)
            CHK?RP  Wout
            incf    Wout, F
            btfsc   STATUS, Z
            incf    Wout + 1, F
            movlw   low (Cin)
            CHK?RP  Wout
            addwf   Wout, F
            if (((Cin) >> 8) == 0)
            btfsc   STATUS, C
            incf    Wout + 1, F
            movlw   (Cin) >> 8
            btfsc   STATUS, C
            addlw   1
            addwf   Wout + 1, F
            movlw   low (Cin)
            CHK?RP  Win
            addwf   Win, W
            MOVE?AB Wout
            MOVE?BA Win + 1
            btfsc   STATUS, C
            addlw   1
            MOVE?AB Wout + 1
            movlw   (Cin) >> 8
            btfsc   STATUS, C
            addlw   1
            CHK?RP  Win
            addwf   Win + 1, W
            MOVE?AB Wout + 1
    CMPGE?WCL macro Win, Cin, Label
            MOVE?WW Win, R0
            MOVE?CB (Cin) >> 8, R1 + 1
            MOVE?CA low (Cin)
            L?CALL  CMPGE
            BIT?GOTO 0, STATUS, Z, Label
    CMPGE_USED = 1
    GOTO?L macro Label
            L?GOTO  Label
    	LIST
    asm:
    PM_USED			EQU	1
    	INCLUDE	"16F628A.INC"
    ; Define statements.
    #define		OSC		 20
    RAM_START       		EQU	00020h
    RAM_END         		EQU	0014Fh
    RAM_BANKS       		EQU	00003h
    BANK0_START     		EQU	00020h
    BANK0_END       		EQU	0007Fh
    BANK1_START     		EQU	000A0h
    BANK1_END       		EQU	000EFh
    BANK2_START     		EQU	00120h
    BANK2_END       		EQU	0014Fh
    EEPROM_START    		EQU	02100h
    EEPROM_END      		EQU	0217Fh
    R0              		EQU	RAM_START + 000h
    R1              		EQU	RAM_START + 002h
    R2              		EQU	RAM_START + 004h
    R3              		EQU	RAM_START + 006h
    R4              		EQU	RAM_START + 008h
    R5              		EQU	RAM_START + 00Ah
    R6              		EQU	RAM_START + 00Ch
    R7              		EQU	RAM_START + 00Eh
    R8              		EQU	RAM_START + 010h
    FLAGS           		EQU	RAM_START + 012h
    GOP             		EQU	RAM_START + 013h
    RM1             		EQU	RAM_START + 014h
    RM2             		EQU	RAM_START + 015h
    RR1             		EQU	RAM_START + 016h
    RR2             		EQU	RAM_START + 017h
    _Zahl            		EQU	RAM_START + 018h
    _PORTL           		EQU	 PORTB
    _PORTH           		EQU	 PORTA
    _TRISL           		EQU	 TRISB
    _TRISH           		EQU	 TRISA
    	INCLUDE	"KKK.MAC"
    	INCLUDE	"PBPPIC14.LIB"
    	LABEL?L	L00001
    	CMPGE?WCL	_Zahl, 0EA60h, L00002
    	ADD?WCW	_Zahl, 001h, _Zahl
    	GOTO?L	L00001
    	LABEL?L	L00002
    How do you filter out the information needed?
    Quote Originally Posted by Ted's View Post
    There's a checkbox in MCS for telling MCS to kick out a .lst file during the compilation.
    Put easily recognizable labels before and after the code section that your after in your PBP source and when the .lst file gets created, do a search (Ctrl-F) for those labels and you should be able to see them right off.
    Ted's's Avatar
    Ted's Guest
    This is what is written in between
       48						LABEL?L	L00001
         +					        LALL
         +	0019-				L00001
        49						CMPGE?WCL	_Zahl, 0EA60h, L00002
         +	0019- 0838			        movf    _Zahl, W
         +	001A- 00A0			        movwf   R0
         +	001B- 0839			        movf    (_Zahl) + 1, W
         +	001C- 00A1			        movwf   (R0) + 1
         +	001D- 30EA			        movlw   low ((0EA60h) >> 8)
         +	001E- 00A3			        movwf   R1 + 1
         +	001F- 3060			        movlw   low (low (0EA60h))
         +	0020- 2001			        call    CMPGE
         +	0021- 1D03			        btfss   STATUS, Z
         +	0022- 2827			        goto    L00002
        50						ADD?WCW	_Zahl, 001h, _Zahl
         +	0023- 0AB8			        incf    _Zahl, F
         +	0024- 1903			        btfsc   STATUS, Z
         +	0025- 0AB9			        incf    _Zahl + 1, F
        51						GOTO?L	L00001
         +	0026- 2819			        goto    L00001
        52						LABEL?L	L00002
         +					        LALL
         +	0027-				L00002
        53
    What is more, there is no question about my configuration. It is a timing issue. The osc value determines the speed to let the program know how many cycles one millisecond will take f.i.. Knowing the speed there is enough information to reproduce the question and to give an answer. I am not here to relearn what would take others just a few seconds to reproduce - less than writing a "do it yourself" takes.
    I am going to use Jackson's 3us and this is the end of the story.
    Do not make things more complicated than they have to be.
    Unhappy
    Your result is :
    504.027000 ms ... @ 8.4 µs per loop !!!
    3 minutes to get it with MPSIM , as we had explained you ...
    Ted's's Avatar
    Ted's Guest
    You see, simple and easy for an experienced programmer.
    Why did you not just do that in the first place?
    So my code will be:
    Zahl VAR WORD
    time_in_us VAR WORD
    DEFINE OSC 20
    WHILE Zahl < 60000
        Zahl = Zahl + 1
    WEND
    time_in_us = Zahl * (84/10)
    Ted's's Avatar
    Ted's Guest
    One thing to clarify: Is there a difference regarding the time being elapsed when using BYTE for Zahl instead of WORD?
    So
    Zahl VAR WORD
    is being replaced by
    Zahl VAR BYTE
    Yes, because comparing 2 words could take 2 comparisons....Check the high byte, if it's equal, then you have to go on and check the low byte.
    Post
    1) Cause here, we teach people how to catch the fish ... it's not a PbP "Drive in" !!!
    2) Cause there was NO answer to what you had asked ... and no way to understand what you wanted to do ...
    3) Still no way to understand ... :
    Zahl VAR WORD
    time_in_us VAR WORD
    DEFINE OSC 20
    WHILE Zahl < 60000
        Zahl = Zahl + 1
    WEND
    ... with this code, "Time_in_us" WON' T be 504 027 ... so, why re-calculate it ???
    ... I do not joke : with the calculation errors ( roundings ) , the showed result will be ... FALSE !!!
    Was I Spiritual enough ???
  1. Newb Question...
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2009, 21:49
  2. IF question.
    By Steve Matson in forum General
    Last Post: - 23rd November 2007, 04:15
  3. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  4. A simple startup question
    By teilhardo in forum General
    Last Post: - 7th January 2006, 21:33
  5. simple newb question
    By PICMAN in forum General
    Last Post: - 5th February 2005, 03:16
