A simple and basic question
Results 1 to 36 of 36
    T.Jackson's Avatar
    T.Jackson Guest
    I think what Ted is actually asking is something like this ...
    DEFINE OSC 20
    WHILE Zaehler_Word <> 60000
       Zaehler_Word = Zaehler_Word + 1
    WEND
    With a 20MHz osc, how long did it take for Zaehler_Word to reach 60,000?
    Trent Jackson
    Wink
    Hi, Trent
    Once, the littles things I raised up have been solved ... a little round in MPSIM is the next step ...
    To be sure ...
    T.Jackson's Avatar
    T.Jackson Guest
    Default Meaningful Question Ted
    I think that the question is very "meaningful" and not so easy to accurately answer without going into assembly routines. I say this because you need to know the number of instruction cycles needed for each mnemonic, the time taken for each cycle (around 1uS at 4MHz I think), and finally what OP codes are driving the PBP instructions. You need to have a good understanding of assembly code to be able to work it out, which I don't have, otherwise I'd provide an answer.
    Trent Jackson
    Wink
    I remember Darrel wrote a little bit of program to measure program parts duration ... a SEARCH through those columns will be welcome.
    The second way is to use MPSIM ( part of MPLAB ) with the stopwatch : result is quite perfect !
    T.Jackson's Avatar
    T.Jackson Guest
    @20MHz I'm guessing ~3uS per iteration of the loop.
    Trent Jackson
    Ted's's Avatar
    Ted's Guest
    I do not understand your answers.
    What you need to take out of this:
    If you loop a variable from zero to 60000 on a pic being driven by a 20Mhz Quartz using the pbp code WHILE without adding a Pauseus XY into the loop, what does this value tell me about the time being elapsed.
    Angry So, was a Stupid question ...
    Quote Originally Posted by Ted's View Post
    So, WE CANNOT ANSWER YOUR QUESTION ...
    IF A = 0 ... the loop won't be executed ...
    IF A != 0 ... The loop is infinite ...
    so, the loop will last as long as A != 0 ...
    This is what you have to take out of your hasty code snippet ...
    Ted's's Avatar
    Ted's Guest
    We? Are you schizophrenic?
  1. Newb Question...
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2009, 21:49
  2. IF question.
    By Steve Matson in forum General
    Last Post: - 23rd November 2007, 04:15
  3. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  4. A simple startup question
    By teilhardo in forum General
    Last Post: - 7th January 2006, 21:33
  5. simple newb question
    By PICMAN in forum General
    Last Post: - 5th February 2005, 03:16
