A simple and basic question
Results 1 to 36 of 36
    Ted's's Avatar
    Ted's Guest
    I do not understand your answers.
    What you need to take out of this:
    If you loop a variable from zero to 60000 on a pic being driven by a 20Mhz Quartz using the pbp code WHILE without adding a Pauseus XY into the loop, what does this value tell me about the time being elapsed.
    Angry So, was a Stupid question ...
    Quote Originally Posted by Ted's View Post
    So, WE CANNOT ANSWER YOUR QUESTION ...
    IF A = 0 ... the loop won't be executed ...
    IF A != 0 ... The loop is infinite ...
    so, the loop will last as long as A != 0 ...
    This is what you have to take out of your hasty code snippet ...
    Ted's's Avatar
    Ted's Guest
    We? Are you schizophrenic?
    Angry
    your answers.
    I only remember having responded ONCE to you ... and I do think no one here can give you a precise time as an answer. ( except Fernand REYNAUD's " a certain time" ... Lol )
    End of File for me ...
    The best way to get your answer is to compile the code, look at the assembly listing, and compute the time to execute one cycle from that. Then multiply it by the number of cycles the loop is expected to run. You also need to check the PIC assembly code docs to see how long it takes to execute each assembly code. I have done this a lot in order to determine how long my interrupt routines are.
    Also I think some of the comments are about the fact that the code sample you gave may not run the way you expect. "A" is not defined so the WEND duration is unknown. Also, A does not change so it is not a good loop control variable.
    I wonder if someone has written a program that reads assembler files and tags execution times to all the microcode.
    Tim Barr
    T.Jackson's Avatar
    T.Jackson Guest
    Wink
    Don't worry about Alain, he doesn't bite, as long as he takes his meds he's fine. But when he forgets to take them
    Ted's's Avatar
    Ted's Guest
    Please muzzle him to be sure he won't bite.
    T.Jackson's Avatar
    T.Jackson Guest
    Nah, I think we'll put his medication up to 1000mg of Chlorpromazine
    T.Jackson's Avatar
    T.Jackson Guest
    Wink
    You'll be a new a man in a couple of weeks Alain ...
    Chlorpromazine is used to treat psychotic disorders and symptoms such as hallucinations, delusions, and hostility. Take two tablets twice a day with food.
    Side Effects
    - Shaking (like Parkinson's Disease)
    - Stiffness
    - Restlessness
    - Problems with sex life
    - Decreased appitite
    Shocking side effects with Chlorpromazine -- I don't know what's worse, being schizophrenia or taking Chlorpromazine!
    But I guess that the good news is that you're not schizophrenic Alain, at least I don't think so ...
    Trent Jackson
    How 'bout we get you 1mg of STFU?
  1. Newb Question...
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2009, 21:49
  2. IF question.
    By Steve Matson in forum General
    Last Post: - 23rd November 2007, 04:15
  3. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  4. A simple startup question
    By teilhardo in forum General
    Last Post: - 7th January 2006, 21:33
  5. simple newb question
    By PICMAN in forum General
    Last Post: - 5th February 2005, 03:16
