A simple and basic question
Results 1 to 36 of 36
    T.Jackson's Avatar
    T.Jackson Guest
    Default Meaningful Question Ted
    I think that the question is very "meaningful" and not so easy to accurately answer without going into assembly routines. I say this because you need to know the number of instruction cycles needed for each mnemonic, the time taken for each cycle (around 1uS at 4MHz I think), and finally what OP codes are driving the PBP instructions. You need to have a good understanding of assembly code to be able to work it out, which I don't have, otherwise I'd provide an answer.
    Trent Jackson
    Wink
    I remember Darrel wrote a little bit of program to measure program parts duration ... a SEARCH through those columns will be welcome.
    The second way is to use MPSIM ( part of MPLAB ) with the stopwatch : result is quite perfect !
    T.Jackson's Avatar
    T.Jackson Guest
    @20MHz I'm guessing ~3uS per iteration of the loop.
    Trent Jackson
    Ted's's Avatar
    Ted's Guest
    I do not understand your answers.
    What you need to take out of this:
    If you loop a variable from zero to 60000 on a pic being driven by a 20Mhz Quartz using the pbp code WHILE without adding a Pauseus XY into the loop, what does this value tell me about the time being elapsed.
    Angry So, was a Stupid question ...
    Quote Originally Posted by Ted's View Post
    So, WE CANNOT ANSWER YOUR QUESTION ...
    IF A = 0 ... the loop won't be executed ...
    IF A != 0 ... The loop is infinite ...
    so, the loop will last as long as A != 0 ...
    This is what you have to take out of your hasty code snippet ...
    Ted's's Avatar
    Ted's Guest
    We? Are you schizophrenic?
    Angry
    your answers.
    I only remember having responded ONCE to you ... and I do think no one here can give you a precise time as an answer. ( except Fernand REYNAUD's " a certain time" ... Lol )
    End of File for me ...
    T.Jackson's Avatar
    T.Jackson Guest
    Wink
    Don't worry about Alain, he doesn't bite, as long as he takes his meds he's fine. But when he forgets to take them
  1. Newb Question...
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2009, 21:49
  2. IF question.
    By Steve Matson in forum General
    Last Post: - 23rd November 2007, 04:15
  3. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  4. A simple startup question
    By teilhardo in forum General
    Last Post: - 7th January 2006, 21:33
  5. simple newb question
    By PICMAN in forum General
    Last Post: - 5th February 2005, 03:16
