A simple and basic question
Results 1 to 36 of 36
    Ted's's Avatar
    Ted's Guest
    You see, simple and easy for an experienced programmer.
    Why did you not just do that in the first place?
    So my code will be:
    Zahl VAR WORD
    time_in_us VAR WORD
    DEFINE OSC 20
    WHILE Zahl < 60000
        Zahl = Zahl + 1
    WEND
    time_in_us = Zahl * (84/10)
    Ted's's Avatar
    Ted's Guest
    One thing to clarify: Is there a difference regarding the time being elapsed when using BYTE for Zahl instead of WORD?
    So
    Zahl VAR WORD
    is being replaced by
    Zahl VAR BYTE
    Quote Originally Posted by Ted's View Post
    Yes, because comparing 2 words could take 2 comparisons....Check the high byte, if it's equal, then you have to go on and check the low byte.
    Post
    1) Cause here, we teach people how to catch the fish ... it's not a PbP "Drive in" !!!
    as we had explained you ...
    2) Cause there was NO answer to what you had asked ... and no way to understand what you wanted to do ...
    3) Still no way to understand ... :
    Zahl VAR WORD
    time_in_us VAR WORD
    DEFINE OSC 20
    WHILE Zahl < 60000
        Zahl = Zahl + 1
    WEND
    ... with this code, "Time_in_us" WON' T be 504 027 ... so, why re-calculate it ???
    ... I do not joke : with the calculation errors ( roundings ) , the showed result will be ... FALSE !!!
    Was I Spiritual enough ???
  1. Newb Question...
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2009, 21:49
  2. IF question.
    By Steve Matson in forum General
    Last Post: - 23rd November 2007, 04:15
  3. Visual Basic 6 question
    By Christopher4187 in forum Off Topic
    Last Post: - 3rd July 2006, 14:06
  4. A simple startup question
    By teilhardo in forum General
    Last Post: - 7th January 2006, 21:33
  5. simple newb question
    By PICMAN in forum General
    Last Post: - 5th February 2005, 03:16
