Instant Interrupts - Revisited
Results 1 to 40 of 773
    Dec 2005
    Post
    Hello all
    Today I play with " Instant Interrupts" thank's Darrel
    For to begin I use blinky program
    I want to augment the speed of blink light by loading a value
    in TMR1H and TMR1L but the speed does not change
    Rq:
    I want not to change the value of the prescaler
    code:
    TMR1H = %11111111
    TMR1L = %11111110
    1CON = %110001 ; Prescaler = 8, TMR1ON
    what is wrong please?
    Quote Originally Posted by debutpic View Post
    code:
    TMR1H = %11111111
    TMR1L = %11111110
    Loading that value %1111111111111110 = $FFFE = 65534
    Means the timer will overflow after only 2 ticks.
    A smaller number would help.
    Also, it has to be loaded after every interrupt, not just at the beginning of the program.
    Dec 2005
    thank's Darrel
    Remark:
    In my next code if I load TMR1H with a high value code work fine
    TMR1H = %11111111
    pause 1
    but if I reduce the value in TMR1H code don't work
    display is OFF
    TMR1H = %10111111
    pause 1
    if I want use this value "TMR1H = %10111111"
    I must write "pause 20" and not "pause 1"
    an idea ???????
    No, I have no idea what you are doing.
    If you're using a timer, why do you need pauses?
    What frequency are you trying to run the timer at?
    What frequency is your primary oscillator?
    What PIC are you using?
    Dec 2005
    I use one 16F877 MCU to 20 Mhz
    TMR1 produce an interrupt every 0,4 µSec
    for to drive four 7 segment displays (prescaler:1)
    My board developpement is EasyPic4
    If I write not a Pause after TMR1H %11111111
    then the displays don't work
    At 4Mhz, each instruction takes 1 uSec to execute.
    At 20Mhz, each instruciton takes .2 uSec to execute.
    When you take in to account the fact that each jump/return to/from the interrupt handler takes at minimum 4 instructions cycles (2 for the jump into the int handler, 2 for the RETFIE after the handler), which happens to be .8uSec, you have less than ZERO time to do anything.
    Even at 40Mhz, you're still at ZERO time left over.
    At 48Mhz, you might get one instruction in here and there...
    And even at 64Mhz, you probably won't get more than one or two instructions done between interrupts.
    I think it is better to post the details of your project so that you could get a decent help. And the .4usec to drive a LED display, to me seems too little time.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
