Instant Interrupts - Revisited
Results 1 to 40 of 773
    You have to be using MPASM as the assembler.
    The default PM assembler will not work.
    Sep 2007
    USA, CA
    Darrel,
    How about a little tutorial on how to tell which assembler is in use, and how to switch to the mpasm?
    OK, how bout this for detection ...
      ifdef PM_USED
           "Dude, you have to use MPASM with DT_INTS"
    If you put that in your program, and try to assemble it with PM.exe, It will automatically pop-up a window in MicroCode Studio like this ...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2450&stc=1&d=120694493 9" />
    Then you can just click on "Compile Using MPASM", and it will set the MPASM option and compile it.
    If it still fails to compile, you should try this ...
    http://www.picbasic.co.uk/forum/show...5&postcount=11
    I should add that to DT_INTS-14.
    hth,
    Jan 2006
    Istanbul
    Hi DT,
    I wanted to post a "thank you" (also as an informative post).
    For the first time ever, I used your 18F routine (with RX_INT) about a minute ago.
    I saved 3100 bytes!!!
    Really very interesting for me.
    Thanks a lot for your amazing work.
    Hi sayzer,
    2 years and 3 months since you joined.
    What took you so long?
    WOW! Saved 3100 bytes. That's pretty impressive.
    Can I ask what the difference was? or maybe where the savings came from?
    Jan 2006
    Istanbul
    Hi sayzer,
    The interesting part is that I did not change anything other the "int" part.
    That is why it was surprising and "Really very interesting for me".
    You mean that comparing to On-Interrupt of PBP you did a reduction of 3100?
    Feb 2003
    Sydney, Australia
    Default Issue with Timer0 and setting prescaler
    I have been playing with the code shown below on a 16f737 as I was trying to get different prescaler values into the int routinues. As part of the testing I stripped the code right back to just be a simple interrupt with a value loaded into the pre-load registrer, but I seem to end up with an interrupt time of 204uS. According to the Timer Calc in Mister E's PicMulti Calc I should get an interrupt every 5.019mS. (see attached image for capture of the output waveform - I love my PICkit 2!)
    This code is lifted straight from Darells example with the blinky led (1-2-3 version), and all I have done is add the pre-load. I have also removed the pre-load and still get the same time for the interrupt.
    DEFINE OSC 20
    rs_led      var portb.7 ' rs232 led
    led         var portc.4 ' was Data_Out line
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
           INT_Handler   TMR0_INT,  _doBAM,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    OPTION_REG = OPTION_REG & $80 | 1     'Set TMR0 Prescaler to 256, leave RBPU alone
    TMR0 =  158 ' preload with 158 to give 21uS interrupts (at 1:1)
    ' this should then give Interrupt every 5.019mS at 1:256
    @ INT_ENABLE  TMR0_INT     ; enable Timer 1 interrupts
    goto main      ' jump over ISR
    '---[TMR0 - interrupt handler]--------------------------------------------------
    doBAM:
    toggle rs_led
    @ INT_RETURN
     high rs_led
    ' do some flashing led stuff
    high led
    low led
    There has got to be something really simple I am missing...
    bill.
    Last edited by bcd; - 1st May 2008 at 10:19. Reason: Clarification of a few things
    Use OPTION_REG = %11010111
    And load the timer on every interrupt.
    Feb 2003
    Sydney, Australia
    See told you it would be something really simple I missed..
    doBAM:
       toggle rs_led
       TMR0 =  158     ' reload the pre-load
       @ INT_RETURN
    (Hey Darrel - how do you get your code blocks so colourful and properly indented ?)
    bill.
    Quote Originally Posted by bcd View Post
    bill.
    http://www.picbasic.co.uk/forum/showthread.php?t=6221
    The page may take awhile to load.....
    Mar 2006
    Default Turn Interrupt on/off
    Hello;
    I'm Ryan form the Philippines I must admit DTS-14 ints rules!!! i'd like to know how can i turn the interrupt on and off for USART continues recepton I'm using PIC16f877a toggling register PIE.5 doesn't seem to work
    PS.
    Part of my project i'm paying my tuition continue college again OSY for sometime now hehe (",)
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
