Instant Interrupts - Revisited
Results 1 to 40 of 773
    Thank you Darrel,
    That's nice from you.
    By the way ... I also modified "a bit" your Elapsed Timer to get only HHHH:MM:SS, using The Timer 1 Clock with a 32.768 Khz Xtal.
    That gives more computing time for other tasks ... especially other interrupts.
    Jun 2007
    Darrel,
    I downloaded your Instant Interrupts files and I am having trouble compiling them. I am using MPASM assembler with PBP. I take your 3 files and try to compiler them straight from what I downloaded.
    On the DT_INTS-14.bas I get the following:
    Error [113] c:\pbp\pbppic14.lib 1141: Symbol not previously defined (INT_ENTRY)
    On the ReEnterPBP.bas I get the following:
    Warning [207] c:\pbp\reenterpbp.asm 217: Found label after column 1 (INT_RETURN)
    Warning [207] c:\pbp\reenterpbp.asm 313: Found label after column 1 (INT_RETURN)
    Error [116] c:\pbp\reenterpbp.asm 313 : Address label duplicated or different in second pass (INT_RETURN)
    The Elapsed_INT.bas compiles without any errors but gives me the following warning:
    Warning [207] c:\pbp\elapsed_INT.asm 237: Found Label after column 1 INT_RETURN
    Do you have any ideas what might be wrong?
    What do you have in the main program?
    Usually means there isn't an INT_LIST macro.
    The files won't compile without it.
    Jun 2007
    As of yet I have not put your code into my main program. I was just trying to compile each on their own. If I understand you correctly, your code needs to be put of another program or it will not compile. Is that correct?
    That's correct!
    Alain,
    Well, you may have noticed I didn't get the "GLOBAL" for INT_ENABLE/DISABLE put in the last version of DT_INTS-18.
    It turns out that GLOBAL is a reserved word for MPASM. It's used with relocatable code.
    I could have used GLBL or GLBAL I suppose, but somehow
    @ INT_DISABLE GLBL
    Seems even more cryptic than
    GIE = 0
    I still think it should be in there, as should PERIPHERAL, HIPRIORITY and LOWPRIORITY.
    But I'm not sure what the best way is, AKA less confusing.
    Any thoughts?
    Alain,
    @ INT_DISABLE GLBL
    GIE = 0
    Any thoughts?
    Hi, Darrel
    What about
    @ G_INT_DISABLE and @ G_INT_ENABLE ??? ... would be simple enough. ... and it's just "ordinary" macros !!!
    Remember the goal was only to use something simple to remind ( in other words: to use for datasheet non-lovers !!! )
    To me, GIE = 0 is also the simpler ... But, as you've seen, nowadays nobody dares to read the datasheets !!!
    The Tractor computer soft is just finished (!)... I had some precedence headaches ( particularly with // !!! ), and it was really difficult to see what was wrong ...
    despite result was good for setting a flag, operation was wrong !!! ... and was no way to cancel that flag ...
    Now, I must translate my comments to English ...
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 8
