Instant Interrupts - Revisited
Results 1 to 40 of 773
    Apr 2004
    Cool ResetFlag
    Hello,
    I've been reading through the posts regardings the Instant interrupts.
    I'm still a little confused on the usage or setting of the ResetFlag.
    Maybe I overlooked it in the posts but I did not find any info on this.
    In some cases it is set to 'yes' but what is the influence.
    --> ; IntSource, Label, Type, ResetFlag?
    Can someone give me a little explanation on this?
    Thank you.
    Best regards,
    If you set it to YES, you don't need to clear the interrupt flags manually, DT's INT will do it for you.
    If you set it to NO, the program won't reset the interrupt flag, so you'll have to do it yourself. In case you don't, your program will always turn in round in your ISR.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 6
