Instant Interrupts - Revisited - Page 8
Page 8 of 20 FirstFirst ... 45678910111218 ... LastLast
Results 281 to 320 of 773
  1. #281
    Sep 2007
    USA, CA
    Darrel,
    How about a little tutorial on how to tell which assembler is in use, and how to switch to the mpasm?
  2. #282
    OK, how bout this for detection ...
      ifdef PM_USED
           "Dude, you have to use MPASM with DT_INTS"
    If you put that in your program, and try to assemble it with PM.exe, It will automatically pop-up a window in MicroCode Studio like this ...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2450&stc=1&d=120694493 9" />
    Then you can just click on "Compile Using MPASM", and it will set the MPASM option and compile it.
    If it still fails to compile, you should try this ...
    http://www.picbasic.co.uk/forum/show...5&postcount=11
    I should add that to DT_INTS-14.
    hth,
    <br>
    Jan 2006
    Istanbul
    Hi DT,
    I wanted to post a "thank you" (also as an informative post).
    For the first time ever, I used your 18F routine (with RX_INT) about a minute ago.
    I saved 3100 bytes!!!
    Really very interesting for me.
    Thanks a lot for your amazing work.
  4. #284
    Hi sayzer,
    2 years and 3 months since you joined.
    What took you so long?
    WOW! Saved 3100 bytes. That's pretty impressive.
    Can I ask what the difference was? or maybe where the savings came from?
    <br>
    Jan 2006
    Istanbul
    Hi sayzer,
    <br>
    The interesting part is that I did not change anything other the "int" part.
    That is why it was surprising and "Really very interesting for me".
  6. #286
    You mean that comparing to On-Interrupt of PBP you did a reduction of 3100?
    Jan 2006
    Istanbul
    Hi Ioannis,
    Actually I tried different codes after this experiment and came up with these simple results.
    1. In a relatively large code, DT's 18F int routine saves a lot of code space compared to On-Interrupt of PBP as you said.
    Ex: I saved 3100 bytes for the same code (code size : approx. 18,000 bytes).
    2. In a small code, DT's 18F routine becomes code hungry.
    Ex: PBP On-Interrupt produces 318 bytes for a sample code I just tried, but
    DT's 18F int routine produces 762 bytes. More then twice larger!
    As the code gets longer, DT's int routine gets handier I suppose.
  8. #288
    Since On Interrupts of PBP puts a check every assembly instructions is obvious why is that code explosion!
    Sure Darrels routines are fixed in length, so either your code is short or long, these routines are known in length. And in my humbble opinion, comparing Darrels interrupts with PBP interrupts is like comparing apples and oranges. Two different things.
    Mar 2008
    london
    This is a series of include files that simplify the process of creating interrupt driven programs for PicBasic Pro. MPASM required.
    Once you try this, you may never use ON INTERRUPT again.
    <table border=0 cellpadding=5><tr><td valign=top>
    Features:
    Assembly language Interrupts
    Basic language Interrupts
    Both ASM and Basic interrupts in the same program
    Service Multiple Interrupt sources
    Prioritized execution order
    Very easy to use
    No ON INTERRUPT "Code Bloat"
    No ON INTERRUPT " I'll service your interrupt
    &nbsp; whenever I feel like it." mentality.
    One of the best things about this system, is that you don't have to remember where all the Enable bits and Interrupt flags are located.
    Each interrupt "source" is given a unique name that is used to reference it. The system "Looks Up" the correct bit locations for that name. &nbsp; Reducing those RTFM sessions to a minimum. &nbsp; The table to the right lists the Named Interrupts.
    </td><td ><table border=1 cellpadding=5><tr><td valign=top nowrap> <center><b>Available Interrupt Sources</b> &nbsp; 14-bit</center><pre> INT_INT -- INT External Interrupt<br> RBC_INT -- RB Port Change Interrupt<br> TMR0_INT -- TMR0 Overflow Interrupt 16F<br> TMR1_INT -- TMR1 Overflow Interrupt<br> TMR2_INT -- TMR2 to PR2 Match Interrupt<br> TX_INT -- USART Transmit Interrupt<br> RX_INT -- USART Receive Interrupt<br> CMP_INT -- Comparator Interrupt<br> EE_INT -- EEPROM/FLASH Write Operation Interrupt<br> BUS_INT -- Bus Collision Interrupt<br> PSP_INT -- Parallel Slave Port Read/Write Interrupt<br> AD_INT -- A/D Converter Interrupt<br> SSP_INT -- Master Synchronous Serial Port Interrupt<br> CCP1_INT -- CCP1 Interrupt<br> CCP2_INT -- CCP2 Interrupt</pre></td></tr></table></td></tr></table>Here's a simple example of toggling an LED using the external interrupt (INT). (Hello World)
    <font color="#000000"><b>LED1   </b><font color="#008000"><b>VAR  </b></font><b>PORTB</b>.<b>1
    </b><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;DT_INTS-14.bas&quot;     </font><font color="#0000FF"><b><i>' Base Interrupt System
    </i></b></font><font color="#008000"><b>INCLUDE </b></font><font color="#FF0000">&quot;ReEnterPBP.bas&quot;     </font><font color="#0000FF"><b><i>' Include if using PBP interrupts
    </i></b></font><font color="#008000"><b>ASM
    </b></font><font color="#000080">INT_LIST  macro    </font><font color="#0000FF"><b><i>; IntSource,        Label,  Type, ResetFlag?
            </i></b></font><font color="#000080">INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
        INT_CREATE               </font><font color="#0000FF"><b><i>; Creates the interrupt processor
        </i></b></font><font color="#000080">INT_ENABLE   INT_INT     </font><font color="#0000FF"><b><i>; enable external (INT) interrupts
    </i></b></font><font color="#008000"><b>ENDASM
    </b></font><b>Main</b>:
      <font color="#008000"><b>PAUSE </b></font><b>1
    </b><font color="#008000"><b>GOTO </b></font><b>Main
    </b><font color="#0000FF"><b><i>'---[INT - interrupt handler]---------------------------------------------------
    </i></b></font><b>ToggleLED1</b>:
         <font color="#008000"><b>TOGGLE </b></font><b>LED1
    </b><font color="#000080">@ INT_RETURN</font>
    <font size=-2>Code Size = 234 words</font>
    <script language="javascript" src="http://www.darreltaylor.com/files/forum_ii.js"></script>
    This project, and it's associated files, have been moved.
    Please download them from my website.
    DT_INTS-14 (12F-16F)
    http://darreltaylor.com/DT_INTS-14/intro.html
    DT_INTS-18 (18F)
    http://darreltaylor.com/DT_INTS-18/home.html
    <br>
    hello,
    i just tested the program with the 16f88 but it s not working , there are some error messages.
    dont know exactly what to do next
    can u give me some advices please??
    thanx
  10. #290
    NO.. at least give more details... error message, code etc etc
    Make sure you're using MPASM to compile
  11. #291
    skimask's Avatar
    skimask Guest
    Judging from the:
    @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
    in the rest of the posts...hmmmmmmmmmmm........
  12. #292
    Jul 2007
    WoW!
    those routines works like magic for a noobie like me
    I've found out that most of my code must be done inside the interrupt part, otherwise if it's in the Main loop it can get trashed by the interrupt(like SEROUT to a serial LCD), but it got my
    latest project running very quickly.
    tnx Darrel
  13. #293
    Default Int_return
    First of all thanx for the code my interups now gets handeled fast enoug so i dont loose any serial data, one problem for some reason my program do not return from the interupt.
    Any ideas
    i use a 16f913
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    DEFINE OSC 20				' Define crystal as 20Mhz
    '*Serial port Setup 9600 8N1*
    DEFINE HSER_BAUD 9600 		; 9600 Baud
    DEFINE HSER_RCSTA 90h 		' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h 		' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1  		; Clear overflow automatically
    '*ADC setup*
    DEFINE ADC_BITS 10 			'SETS NUMBER OF BITS IN RESULTS 8,10,12
    DEFINE ADC_CLOCK 3 			'SETS CLOCK SOURCE (RC = 3)
    DEFINE ADC_SAMPLEUS 50 		'SETS SAMPLING TIME IN MICROSECONDS
    'This Part set PORTA 0-5 an analog inputs
    ADCON1 = %01110000			'FRC (clock derived from a dedicated internal oscillator = 500 kHz max)
    ANSEL  = %00011111			'The ANSEL (91h) and CMCON0 (9Ch)registers must be initialized to configure an
    CMCON0 = %00000111			'analog channel as a digital input. Pins configured as analog inputs will read ‘0’.
    TRISA  = %00011111			'set PORTA 0-5 as inputs
    ADCON0.7 = 1				'Right justify output of ADC datasheet P145 of 16F913
    TRISC = %10000000			'Set PORTC for serial coms and pins  as output
    TRISB = %00000000			'Sert PORTb as outputs and for use with the ICD2
    V1 var WORD
    ID var byte[28]
    CELL1	VAR BYTE[11]
    I	VAR BYTE
    PORTC = 0
    INT_LIST  macro ; IntSource,        Label,  Type, ResetFlag?
        INT_Handler    RX_INT,  _IntLoop,   ASM,  yes
        INT_CREATE               		; Creates the interrupt processor
    	INT_ENABLE   RX_INT     		; enable external (RX) interrupts
    		PORTC.5=1
    		PAUSE 200
    		PORTC.5=0
    		PAUSE 200
    		PORTC.5=1
    		PAUSE 200
    		PORTC.5=0
    goto Main
    IntLoop:
    	HSERIN [WAIT("^SMGL:"),SKIP 1 ,str ID\28]
        HSEROUT ["CELL NO:",_
              ID[17],iD[18],ID[19],ID[20],ID[21],ID[22],_
              ID[23],ID[24],ID[25],ID[26],ID[27],10,13]
    @ INT_RETURN
    As you're using HSERIN/HSEROUT, shouldn't RX_INT be PBP type instead?
    Don't forget to add ReEnterPBP.bas in your INCLUDE list.
  15. #295
    Feb 2005
    Kolkata-India
    Talking Mister-e is right.
    I thought I could point this out. This forum is fortunate that there are less people like me. Late and lazy.
    BTW Steve everytime I see the avatar banging head on the keyboard I feel concerned. Please stop banging your head. Its costly. I mean the keyboard that is...
    Sougata
  16. #296
    LMAO! well this avatar is really me... if you feel concern... i'm sorry
    I see some other potential problem in the above anyways.
    From one of his previous post he says that
    ^SMGL: 1,"REC UNREAD","+27829554322",,"08/04/20,17:12:09+08"
    could be the incoming string... so obviously, using his HSERIN line, it may return to the INT routine and spining around and around. my 2nd suggestion add a little timeout like this...
    IntLoop:
        HSERIN 10, GETOUT,[WAIT("^SMGL:"),SKIP 1 ,str ID\28]
    GETOUT:
    @ INT_RETURN
    this way + PBP type it should solve most, see all problems.
    HTH
  17. #297
    Smile
    Thanks mister-e the second suggestion with the time out did the trick, still not hundred present sure why it works like that but shore are glad it works
    Thanks again
  18. #298
    look post 296... if i was right, your PIC will wait 'till the next time it receive ^SMGL: when the timeout is not used.
  19. #299
    Feb 2003
    Sydney, Australia
    Default Issue with Timer0 and setting prescaler
    I have been playing with the code shown below on a 16f737 as I was trying to get different prescaler values into the int routinues. As part of the testing I stripped the code right back to just be a simple interrupt with a value loaded into the pre-load registrer, but I seem to end up with an interrupt time of 204uS. According to the Timer Calc in Mister E's PicMulti Calc I should get an interrupt every 5.019mS. (see attached image for capture of the output waveform - I love my PICkit 2!)
    This code is lifted straight from Darells example with the blinky led (1-2-3 version), and all I have done is add the pre-load. I have also removed the pre-load and still get the same time for the interrupt.
    DEFINE OSC 20
    rs_led      var portb.7 ' rs232 led
    led         var portc.4 ' was Data_Out line
           INT_Handler   TMR0_INT,  _doBAM,   PBP,  yes
    OPTION_REG = OPTION_REG & $80 | 1     'Set TMR0 Prescaler to 256, leave RBPU alone
    TMR0 =  158 ' preload with 158 to give 21uS interrupts (at 1:1)
    ' this should then give Interrupt every 5.019mS at 1:256
    @ INT_ENABLE  TMR0_INT     ; enable Timer 1 interrupts
    goto main      ' jump over ISR
    '---[TMR0 - interrupt handler]--------------------------------------------------
    doBAM:
    toggle rs_led
    @ INT_RETURN
     high rs_led
    ' do some flashing led stuff
    high led
    low led
    There has got to be something really simple I am missing...
    bill.
    Last edited by bcd; - 1st May 2008 at 09:19. Reason: Clarification of a few things
  20. #300
    Use OPTION_REG = %11010111
    And load the timer on every interrupt.
    <br>
    Feb 2003
    Sydney, Australia
    See told you it would be something really simple I missed..
    doBAM:
       toggle rs_led
       TMR0 =  158     ' reload the pre-load
       @ INT_RETURN
    (Hey Darrel - how do you get your code blocks so colourful and properly indented ?)
    bill.
  22. #302
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by bcd View Post
    bill.
    http://www.picbasic.co.uk/forum/showthread.php?t=6221
    The page may take awhile to load.....
  23. #303
    Mar 2006
    Default Turn Interrupt on/off
    Hello;
    I'm Ryan form the Philippines I must admit DTS-14 ints rules!!! i'd like to know how can i turn the interrupt on and off for USART continues recepton I'm using PIC16f877a toggling register PIE.5 doesn't seem to work
    PS.
    Part of my project i'm paying my tuition continue college again OSY for sometime now hehe (",)
  24. #304
    Check out this post, esp. post 5, http://www.picbasic.co.uk/forum/showthread.php?t=3251
  25. #305
    you can use
    @ INT_ENABLE RX_INT
    and
    @ INT_DISABLE RX_INT
  26. #306
    Mar 2006
    Wink fixed it
    ahhh thanks guys
    fixed it toggling both
    ' CREN = 0
    ' SPEN = 0
    I didn't bother with the interrupts just disabled the Port input thanks I appreciate it!!!
  27. #307
    Dec 2007
    Cd. Juarez, Mexico
    Hi Darrell, I tried to use your great rutines without any luck. I'm using a 18F248 sending CAN messages and I want to use a timer interrupt to send it.
    Just to test the rutines I tried to compile the example you post for timer interrupt and DT_INTS-18.bas rutines. But I got some errors on the compilation. Attached you will find a screen shot of what i'm talking about. If anybody can tell me what I'm doing wrong, it will be a great help for me.
    Thanks in advance for all yor help
    Alfredo
  28. #308
    Hi Alfredo,
    Well apparently, not all CAN modules are the same.
    There are 2 types, CAN and ECAN.
    I didn't consider the plain CAN module when I wrote it.
    I'll have to make a way for it to detect which module is available and only use the interrupts for it. Then I'll post an update.
    But for now, you can just comment out the interrupt Sources that aren't available.
    In the DT_INTS-18.bas file, comment out the following lines in the CAN Module section ...
    asm  ; -- CAN Module --
      ifdef WAKIF
                   ;----{ CAN bus Error }------------------------[PIR3, ERRIF]---
          INT_Source  CAN_ERR_INT, PIE3,ERRIE, IPR3,ERRIP
                   ;----{ Invalid Received Message }-------------[PIR3, IRXIF]---
          INT_Source  CAN_IRX_INT, PIE3,IRXIE, IPR3,IRXIP
                   ;----{ Receive Buffer 0 }------Mode 0--------[PIR3, RXB0IF]---
          INT_Source  CAN_RXB0_INT, PIE3,RXB0IE, IPR3,RXB0IP
                   ;----{ FIFO Watermark }--------Mode 1, 2---[PIR3, FIFOWMIF]---
    ;      INT_Source  CAN_FIFOWM_INT, PIE3,FIFOWMIE, IPR3,FIFOWMIP
                   ;----{ Receive Buffer 1 }------Mode 0--------[PIR3, RXB1IF]---
          INT_Source  CAN_RXB1_INT, PIE3,RXB1IE, IPR3,RXB1IP
                   ;----{ Any Receive Buffer }----Mode 1, 2-----[PIR3, RXBnIF]---
    ;      INT_Source  CAN_RXBn_INT, PIE3,RXBnIE, IPR3,RXBnIP
                   ;----{ Transmit Buffer 0 }-------------------[PIR3, TXB0IF]---
          INT_Source  CAN_TXB0_INT, PIE3,TXB0IE, IPR3,TXB0IP
                   ;----{ Transmit Buffer 1 }-------------------[PIR3, TXB1IF]---
          INT_Source  CAN_TXB1_INT, PIE3,TXB1IE, IPR3,TXB1IP
                   ;----{ Transmit Buffer 2 }-----Mode 0=-------[PIR3, TXB2IF]---
          INT_Source  CAN_TXB2_INT, PIE3,TXB2IE, IPR3,TXB2IP
                   ;----{ Any Transmit Buffer }---Mode 1, 2-----[PIR3, TXBnIF]---
    ;      INT_Source  CAN_TXBn_INT, PIE3,TXBnIE, IPR3,TXBnIP
                   ;----{ CAN bus Activity Wake-up }-------------[PIR3, WAKIF]---
          INT_Source  CAN_WAKE_INT, PIE3,WAKIE, IPR3,WAKIP
      list
      list
    Thanks for the info!
    Dec 2007
    Cd. Juarez, Mexico
    Thumbs up
    WOOOOW!
    Thank you very much for the info, now I can use your rutines!!! Your info fix my problem
    Thanks again!!!
    Alfredo
  30. #310
    .Damn.. way to slow this time
    my solution was..
    asm
    RXBnIF=RXB1IF
    TXBnIF=TXB2IF
    FIFOWMIF=RXB0IF
    INT_LIST    MACRO
        INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
        INT_CREATE
       endasm
    From p18f8680.inc file...
    ;----- PIR3 Bits -----------------------------------------------------
    RXB0IF           EQU  H'0000'
    RXB1IF           EQU  H'0001'
    TXB0IF           EQU  H'0002'
    TXB1IF           EQU  H'0003'
    TXB2IF           EQU  H'0004'
    ERRIF            EQU  H'0005'
    WAKIF            EQU  H'0006'
    IRXIF            EQU  H'0007'
    FIFOWMIF         EQU  H'0000'
    RXBnIF           EQU  H'0001'
    TXBnIF           EQU  H'0004'
    On another hand... seems odd...
  31. #311
    Good one Steve. That would have worked too.
    Since they're actually the same bit's, but with different Names depending on the mode, that might be an easy way for me to fix it. Maybe.
    <br>
    But yeah... we know how Microchip work... hard to tell if it will always work... on all PIC
    Worth a try!
  33. #313
    Oct 2003
    Australia
    Question
    Steve,
    Do you know if the there is any difference in accuracy between using a xtal osc and the internal RC osc esp. in relation to timer interrupts?
    Squib
  34. #314
    Must be Steve's day off.
    Hi Squib,
    Well it depends on the internal oscillator type, and how you're using the interrupts.
    The typical general purpose crystal will have a tolerance of +/- 50 PPM (Parts per million) Although there are other crystals with tighter tolerances, some down to less than 1 PPM. But they come at a higher cost.
    If you're using one of the older 4mhz internal oscillators, depending on temperature and proper calibration numbers, they can vary up to +/-10% (100,000 PPM). A HUGE difference.
    The newer 8mhz oscillators will vary a modest +/- 2.5% over the temperature range, but that's still 25,000 PPM.
    If the interrupts are being used for "Long Term" timing like a clock, a difference of 1 PPM translates to an error of +/- 31.5 seconds per year. At 50 PPM it's 26.3 minutes/yr
    But with the 8mhz INT_OSC, you're looking at a whopping 9.1 Days/Yr.. And with the old 4mhz osc you're off by +/-36.5 days. Yikes!
    Of course these are "Worst case" numbers with maximum temperature extremes, actual results may vary.
    hth,
    Sep 2007
    USA, CA
    For reference, I recently tried to see what kind of baud I could get out of my pic serial port, using the internal 8MHz osc. I used an FTDI232R on the PC side, which accepts +/- 3% on the baud rate. The lower baud rates locked in fine, but at 125Kbaud, I had to slow the PIC baud rate down to 118k to 124k. (I did not try any fractions to get more precise failure speeds.) Apparently at the temperature of that particular pic at that particular time, the oscillator was running about 3% fast. That's 30,000 parts per million... way off, I would say.
  36. #316
    Oct 2003
    Australia
    Thanks DT for the info, those are some pretty scarey numbers you pulled up!
    The reason I asked was I have a three minute timer using DT_14 interrupts and I also used Steves Pic timer calc but I'm consistantly getting the timer out by about -10 secs using the int_osc at 8MHz.
    I'll try an ext_xtal and see if I get the same error, but comparing my error to the numbers you pulled up, mines probabaly due to a coding error. :-)
    If I find a difference I'll let you know.
    Cheers
  37. #317
    Quote Originally Posted by Squibcakes View Post
    10 seconds in 3 minutes ....
    That's around a 5.5% error, and the OSC would be 7,555,556 Mhz.
    http://spreadsheets.google.com/pub?k...uiCKE-EFrRLaZA
    I think you're right about it not being the OSC
    Are you using the Timer Template, or the Elapsed Timer?
    Omaha, Nebraska USA
    Thumbs up
    Apropos of nothing in particular . . .
    I finally had a project where I needed a simple background "heartbeat" indicator while doing other things with a 16F627A, so I used Darrel's "overkill" blinky.
    It works like a charm.
    I'll tell everyone this:
    It took a few tries, but solutions for each problem and error message I encountered were found on this site. I just had to Do A Search.
    . . . well, except one instance--I was getting a message that the file path to the source code was too long (something like in excess of 62 characters). So I moved the file set to a different location with a shorter path. Duh!
    I suppose the point I'm making, though, is that beyond RTFM and RTFDS, it doesn't hurt to DAFS.
    The search tool Darrel posted works really well, sometimes with as little as a few words from the error message.
    Kudos to Darrel Taylor!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  39. #319
    Jun 2008
    I'm having problems with my LCD (BPI-216) when using these intterupts.
    When using the code for the clock interrupt and button interrupt the LCD display junk.
    If using only one of the intterupts the junk is less, but still.
    It is mostly happen if pressing then button very often.
    Can someone advice?
  40. #320
    As Steve noted on many post before:
    We are not fortune tellers here. More input as Johnny 5 said once!
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 5
