Help with code
Results 1 to 28 of 28
Thread: Help with code
    Jul 2007
    Yes, it exactly same as the old one..
    You can see how it changes:
    Compiling > Assembling > Success: 82 words used.
    Quote Originally Posted by xobx View Post
    Ok, so the one file with portb.0/portb.1/portb.2 has 82 words used.
    What happens to the same program if you comment out everything under 'loop:' and above 'goto loop', then recompile it?
    Jul 2007
    I just found out that if I change something in this the hex file changes
     @   device  pic16F648A, hs_osc, wdt_on, mclr_on, lvp_off, protect_off
    DEFINE OSC 20
    But if I change something in the rest off the code the hex file doesnt change..
    Jul 2007
    I restarted my computer and now does it work :/
    Wierd!
    Wierd!
    Installed a program and didn't do a restart so Windows internal paths didn't get updated...
    Glad I could help...not...
    Jul 2007
    What, I restarted the computer after I installed everything!
    I didnt install and directly started to use MCS+
    Apparently not...
    Restart it again. Maybe your PIC will program itself with the finished product.
    Jul 2007
    Lets see..
    EDIT: ..nope
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
