try
Also, read the following thread, at least POST#1 and POST#5Code:@ __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF DEFINE OSC 20 loop: high portb.1 pause 500 low portb.1 pause 500 goto loop end
if you're using PM, you will need to use
instead of __CONFIGCode:@ device pic16F648A, hs_osc, wdt_on, mclr_on, lvp_off, protect_off
