Re-Writing IF-THEN-AND-ENDIF code?
Results 1 to 7 of 7
    jessey's Avatar
    jessey Guest
    Default Re-Writing IF-THEN-AND-ENDIF code?
    Hello,
    I wrote a timer program using Darrels
    EE_Vars.PBP
    DT_INTS-18.bas
    ReEnterPBP-18.bas
    Elapsed_INT-18.bas
    and my program works great until I decided to try and save some code space by re-writing some of the code where I used IF-THEN-AND-ENDIF's. I can't seem to convert the code segment below to get it to work, as re-written the alarm won't sound for some reason. I'm using a PIC18f452-20/P. Its really starting to bug me why I can't figure it out as it seems pretty simple and straight forward enough?
    Does anyone have any ideas on what I did wrong?
    jessey
    This code works good.....
    'This is the alarm check. The first IF-THEN here
    'prevents the alarm from sounding when the timer
    'set points aren't set, as it will be on the
    'initial power-up or when both resets buttons
    'have been pressed..............................
    IF Seconds = 0 AND Minutes = 0 AND Hours = 0 AND _
       Seconds_Alarm_Set_Point = 0 AND _
       Minutes_Alarm_Set_Point = 0 AND _
        Hours_Alarm_Set_Point = 0 THEN
    ELSE 'If above code is true then don't check the code below
     IF Start_Stop_Mode = StartTime THEN 'if the clock is running
      IF Seconds = Seconds_Alarm_Set_Point AND _
         Minutes = Minutes_Alarm_Set_Point AND _
            Hours = Hours_Alarm_Set_Point THEN
        GOSUB StopTimer : LOW Clock_Set_Green_Led
        Alarm_Is = On_
    This converted code from above doesn't work.....
    IF Seconds = 0 THEN
     IF Minutes = 0 THEN
      IF Hours = 0 THEN
       IF Seconds_Alarm_Set_Point = 0 THEN
        IF Minutes_Alarm_Set_Point = 0 THEN
         IF Hours_Alarm_Set_Point = 0 then
            IF Hours = Hours_Alarm_Set_Point THEN
             IF Minutes = Minutes_Alarm_Set_Point THEN
              IF Seconds = Seconds_Alarm_Set_Point THEN
                GOSUB StopTimer
                LOW Clock_Set_Green_Led : Alarm_Is = On_
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Although I have not dove into the logic, this could be part of your issues ...
    Darrel's Code Snippet
    Darrel's code goes to "ELSE" if any of the above are not true
    Your Code Snippet
    IF Seconds = 0 THEN
     IF Minutes = 0 THEN
      IF Hours = 0 THEN
    Yours goes to ELSE only if Hours_Alarm_Set_Point =0 is not true, otherwise they go to ENDIF and out of the massive IF-THEN jungle
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    New England
    Another way to do it that might work...
    Since you're checking to see that all those variables = 0, you could just first add them all (making sure that the Temp variable size won't be exceeded), then just test the sum...
    Temp = Seconds + Minutes + Hours + Seconds_Alarm_Set_Point + Minutes_Alarm_Set_Point + Hours_Alarm_Set_Point
    IF Temp=0 THEN  ; test to see if Temp is 0
    ;  do something
    ;  etc, etc
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
    jessey's Avatar
    jessey Guest
    Default Great answers..... thanks
    Hi Paul,
    Quote Originally Posted by paul borgmeier
    Your right on that point Paul, I re-thought it out and came up with this code below and it works......... thanks
    '  This saves 142 bytes
    F VAR BIT
    F = 0
    IF Seconds = 0 THEN F = 1
    IF Minutes = 0 THEN F = 1
    IF Hours = 0 THEN F = 1
    IF Seconds_Alarm_Set_Point = 0 THEN F = 1
    IF Minutes_Alarm_Set_Point = 0 THEN F = 1
    IF Hours_Alarm_Set_Point = 0 then F = 1
      IF F = 0 THEN
             GOSUB StopTimer
             LOW Clock_Active_Green_Led : Alarm_Is = On_
    Quote Originally Posted by Archilochus
    That's a really neat efficient approach Arch and its the one I'll use. I would have never thought of that way of doing it but now I'll never forget it, its one more tool in my tool box now! Thanks a lot guys, I really appreciate your input.
    '  This saves 182 bytes
      Temp = Seconds + Minutes + Hours + Seconds_Alarm_Set_Point + _
      IF Temp = 0 THEN
            GOSUB StopTimer
    jessey
    EDIT: Nevermind.. i misread the Arch post... don't forget to use a Word sized variable is the only thing you need to remember.
    Good night!
    May 2006
    Del Rio, TX, USA
    Jessey,
    Here is a small refinement to your IF-THEN-ENDIF
      IF Temp <> 0 THEN  'Not Equal to 0
                         '<- Eliminates the unused ELSE
                          GOSUB StopTimer
    New England
    Hmmm...
    Maybe could go to this too...
    IF Temp THEN ; Any Temp value over zero will make the "IF" true
     ;do something
    EndIF
    This may not work with older versions of PBP.
    Arch
