I don't understand this code!
Results 1 to 40 of 47
    Apr 2006
    New Hampshire USA
    Smile Aarrrggghh
    Quote Originally Posted by Russ Kincaid View Post
    I hate to tell you this, Adam, but your program makes the outputs high for 4 ms and low for 12 ms, just like mine. And, I am refrencing the scope to VSS.
    Aarrrggghh, I hate hearing that, too!
    Mister-e’s suggestion on the other tread sounds plausible (“Where's the CMCON setting?”).
    The other idea is: you may not be really re-programming the PIC.
    Try changing the times to 100 times longer. Just to check.
    or
    Try erasing the PIC, reading it, look at the hex to make sure it is erased. Then, program it with the new code compiled from MCS and PBP. Then read the device again to see it has really been re-programmed.
    I seem to remember some forum postings about forgetting to re-compile before re-burning.
    So they just kept burning the original (Version 1 of their code) ASM into HEX, not the new PBP (Version 2 of their code).
    -Adam-
    May 2006
    Kedah, Malaysia
    Quote Originally Posted by Pic_User View Post
    or
    -Adam-
    I am proposoing to put NPN transistor to invert the waveform?
    If cannot then fine.
    Jan 2006
    New Hampshire, USA
    Good suggestions, Adam. But, I have done all those things (except make the time longer). Look at post#15, why is that waveform the same as post#1?
    Apr 2006
    New Hampshire USA
    Smile My guess
    Hi Russ,
    Because you are not really re-programming the PIC, with the PBP new program.
    -Adam-
    Hi Russ,Because you are not really re-programming the PIC, with the PBP new program.
    -Adam-
    Entirely possible! It's happened to me more than once!
    Jan 2006
    New Hampshire, USA
    Thanks fellas, I started a new thread and got the answer: CMCON=7. I have not figured out why that works, maybe it is just one of those things I was not meant to know.
    Sep 2006
    Indiana, USA
    Default .
    Hey Russ,
    You're doing a great job with N&V!
    Keep it up!
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
