I don't understand this code!
Results 1 to 40 of 47
    Jan 2006
    New Hampshire, USA
    What I mean by "upside down" is: When the programmed output is high, the output actually goes low and when the programmed output is low, it actually goes high. I don't understand that.
    Russ
    Apr 2006
    New Hampshire USA
    Question upside down
    Hi Russ,
    Quote Originally Posted by Russ Kincaid View Post
    We are not trying to give you a difficult time about this inverted waveform thing. It is just difficult to tell what you are seeing on a recurring waveform. Do you have another circuit synchronized with this output? Are you referencing the measurement to the PIC common?
    The timing may be difficult to see with a rapidly cycling code. You could change the code to seconds, just to watch the sequence.
    It looks like you WANT the output to be HIGH for three time increments and LOW for one. (See attachment.) http://www.picbasic.co.uk/forum/atta...1&d=1178466510
    Is the waveform LOW for three time increments and HIGH for one?
    -Adam-
    Jan 2006
    New Hampshire, USA
    Quote Originally Posted by Pic_User View Post
    Hi Russ,
    -Adam-
    Exactly right. Why does it do that?
    BTW, GPIO.0 produces the positive half of an AC signal while GPIO.1 produces the negative half. The result is an AC that reads the same on a true RMS meter or one that reads 0.7 of the peak.
    I'm thinking it might be time to post your schematic so we can quit guessing and start fixin' !
    Jan 2006
    New Hampshire, USA
    This is a very simple circuit, and not part of the problem, I believe.
    Russ
    Russ
    Turn the LEDs around and connect them to ground.
    When you apply a logic 0 to the pin, the pin sinks current and the LED lights...when you apply a logic 1 to the pin, the LED has the same voltage on both sides and doesn't light up...negative logic.
    That's why everything is backwards...but it's really not...it's working just as designed.
    Jan 2006
    New Hampshire, USA
    No, No, not working as designed. I know I can turn the LEDs around, but I want to know why I have to do that. I suppose I could write the program to do the opposite of what I want and see what happens.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
