I don't understand this code!
Results 1 to 40 of 47
    Apr 2006
    New Hampshire USA
    Unless the guy has REALLY FAST eyes!
    Hard on the eyes!
    Maybe that's why they call it 60 hurts.
    Quote Originally Posted by Pic_User View Post
    Hard on the eyes!
    Me anyways, even after a good sleep and a cup of coffee cannot see the 50 Hz. As for the 60....
    P.S. May be it's the age!
    malc-c's Avatar
    malc-c Guest
    Suggestions:
    1: When developing a project its always worth building the hardware on something like a solderless breadboard as it makes changes a doddle and saves on the cost of designing, etching and then throwing away a PCB.
    2: I always drive LEDs from pins with their own series resistor connected to the pin, and all commoned to GND. Connecting the LEDs from +ve will cause them to light when the PIC provides a source to ground.
    3: At the frequencies you are hoping to monitor (60 Hz) it will be very hard to monitor whats happening with LEDs as the eye will not be able to register the pulses. Try setting the delays and pulse timing to something that you can see, possibly by some scale factor (say by a factor of 10). Once you have the code working with the correct sequence of pins going high and low with the correct delay at this factor, then you can scale it back.
    Just my 2p's worth
    Jan 2006
    New Hampshire, USA
    You guys are cracking me up! Of course I am using a dual trace scope and Pic_User has posted the correct waveform, which I have not been able to produce. I re-installed the software but that was no help. I like the idea of putting extra PAUSEUS in, I will try that.
    Quote Originally Posted by Russ Kincaid View Post
    But we STILL don't know WHERE you are taking your measurements from!
    Pssst.... Look in post #22.....
    Shows where A & B are and what they should be doing on the 'scope, but, doesn't show for sure where he's measuring from.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
