I don't understand this code!
Results 1 to 40 of 47
    Quote Originally Posted by Russ Kincaid View Post
    This is a very simple circuit, and not part of the problem, I believe.
    Russ
    Turn the LEDs around and connect them to ground.
    When you apply a logic 0 to the pin, the pin sinks current and the LED lights...when you apply a logic 1 to the pin, the LED has the same voltage on both sides and doesn't light up...negative logic.
    That's why everything is backwards...but it's really not...it's working just as designed.
    Jan 2006
    New Hampshire, USA
    No, No, not working as designed. I know I can turn the LEDs around, but I want to know why I have to do that. I suppose I could write the program to do the opposite of what I want and see what happens.
    Apr 2006
    New Hampshire USA
    Thumbs up I vote to re-order the code.
    Hi Russ,
    The waveform and any talk about HIGH / LOW is assumed to be in reference to the (ground / common / Vss) of the PIC. Your LEDs are referenced to the plus “rail” of the supply. That would make the LED output appear to be (upside down / negative logic). You could rewire the LEDs or re-order the code.
    By the way, it is very interesting to put both LEDs on the single 1k resistor. Causing the voltage to vary differently when one, two or none of the LEDs are on! Getting, the same reading on a true RMS and a cheap 0.7 of peak meter is not an easy task! Where do you measure the voltage?
    -Adam-
    Jan 2006
    New Hampshire, USA
    I re-wrote the program to produce the opposite waveform, but it is the same waveform:
    LOW GPIO.0 'INITIAL CONDITIONS
    LOW GPIO.1
    START:
    HIGH GPIO.1
    PAUSEUS 4168 ' HIGH TIME
    LOW GPIO.1
    PAUSEUS 4167 'DEAD TIME, BOTH LOW
    HIGH GPIO.0 'SETS PIN 7 HIGH
    PAUSEus 4168 'FOR 4.168 MILLISECONDS
    LOW GPIO.0
    GOTO START '60 HZ FREQUENCY
    Since both programs produce the same waveform, I guess my only option is to turn the LEDs around!
    My circuit is only for testing. If I were driving solid state relays they would burn up when both were on.
    Apr 2006
    New Hampshire USA
    Post oh-oh
    Russ, the code will cause both LEDs to be on at the same time, even if the LEDs are referenced to ground.
    GPIO.0 and GPIO.1 are the same level in the “second” and the “forth” time increment.
    The previously attached waveform drawing shows this.
    http://www.picbasic.co.uk/forum/atta...1&d=1178466510
    You may have forgotten 4.168 milliseconds is one quarter (“one quadrant”) of a full cycle (16.667) – not one half.
    -Adam-
    Might sound a bit silly, but, maybe if you drew us a quick picture of what you want the output to be, like if it was a picture from an o'scope, we might be able to better understand what you actually want.
    The last post by Pic_User sounds like that might be the problem, simple mistake, easily fixed...
    Jan 2006
    New Hampshire, USA
    The waveform posted by Picuser is what I want the output to look like. The actual output is the inverse and I don't understand it. Perhaps my compiler is corrupted?
    I'd highly doubt your compiler is corrupted, but maybe a reinstall is in order.
    And I think post #16 might be your problem in the first place.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
