I don't understand this code!
Results 1 to 40 of 47
    Apr 2006
    New Hampshire USA
    Default okay
    This code should work with the LEDs wired the original way.
    You could even put a time delay before the ON time and after the ON time, to “push” the waveform around. To get the desired timing to get the quasi sine wave at 60 Hz. I have no idea what timing will help!
    Just be sure the total adds up to the times for 60Hz.
    START:
    PAUSEUS 2074 ' before pulse
    LOW GPIO.1 ‘ON = pulse
    PAUSEUS 4168 ' ON TIME - GPIO.1 only
    HIGH GPIO.1 ‘both pins OFF
    PAUSEUS 2074 ' after pulse
    PAUSEUS 20 ' anti-overlap time
    ‘should add to 8.336 milliseconds
    LOW GPIO.0 ‘ON = pulse
    PAUSEUS 4168 ' ON TIME - GPIO.0 only
    HIGH GPIO.0 ‘both pins OFF
    GOTO START '60 HZ FREQUENCY
    I still would like to know between which points are you measuring the wave (voltage) from?
    Quote Originally Posted by Pic_User View Post
    I'm guessing just looking at the LEDs, not actually measuring voltage...
    I could be wrong...been there before
    Apr 2006
    New Hampshire USA
    Smile don't blink
    Bet you’re right. Must be difficult to tell if both come on together at 60 Hz tho...
    Unless the guy has REALLY FAST eyes!
    Apr 2006
    New Hampshire USA
    Hard on the eyes!
    Maybe that's why they call it 60 hurts.
    Hard on the eyes!
    Me anyways, even after a good sleep and a cup of coffee cannot see the 50 Hz. As for the 60....
    P.S. May be it's the age!
    malc-c's Avatar
    malc-c Guest
    Suggestions:
    1: When developing a project its always worth building the hardware on something like a solderless breadboard as it makes changes a doddle and saves on the cost of designing, etching and then throwing away a PCB.
    2: I always drive LEDs from pins with their own series resistor connected to the pin, and all commoned to GND. Connecting the LEDs from +ve will cause them to light when the PIC provides a source to ground.
    3: At the frequencies you are hoping to monitor (60 Hz) it will be very hard to monitor whats happening with LEDs as the eye will not be able to register the pulses. Try setting the delays and pulse timing to something that you can see, possibly by some scale factor (say by a factor of 10). Once you have the code working with the correct sequence of pins going high and low with the correct delay at this factor, then you can scale it back.
    Just my 2p's worth
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
