I think skimask has a very good point. You started with the statement above and are now deeper than you could ever imagine. There is a subtle truth to the KISS principle, it works and it is simple.
- What are your expectations?
- Do you have something that works 4-out-of-5 times? I mean you send the message 5 times and you receive it 4.
- Where you expecting the link to work 100% of the time? If so, do you know what your link budget is? Do you now how much margin you have? What distance you need to cover?
- I do not know of any comm system that works 100% of the time. The best systems (very expensive) use redundancy, error correction, complex modulation schemes, etc. Normal systems (i.e. remotes, sensors, telemetry) usually just encode and send several times.
- You pick what you think you need in terms of reliability and no more usually. If you have way more, you over-designed it (your wasting battery power, causing unintended radiation, or something else).
I am not trying to persuade you from making something better. But seeing how complicated it is getting, do you really need it this complex? Or can you keep your manchester coded signal (which apparently is already working) send it a few times and only use the first one that passes a CRC check or something like that?
