I would use a 5ms pulse as the preamble and a 20ms pause between data packets (it allows the AGC and threshold to reset).
On the receiving end I would use PulsIn to wait for the 5ms pulse and then go into the normal receive routine once it's received. Using some type of error detection (e.g. checksum) is a necessity.
What range do you need? How much data do you need to send?
Looking at the digital data pin with a 'scope (or recording it with a soundcard as I suggested earlier) can eliminate a lot of guesswork by telling you whether your signal strength is adequate. I find it invaluable.
