Transmission works with wires but not always with wireless
Results 1 to 40 of 43
    Serial communication is a female thing, so bear in mind that preamble are needed and some of them may say the size don't make any difference
    Usually 3-5 $AA as preamble is enough. Machester encoding have it's own advantage if you send long data packet. A checksum is also handy.
    I don't think the character pacing (pause x) is really needed if you're using a slow baudrate (2400 bauds or so)
    a single SEROUT/DEBUG/SEROUT2/HSEROUT line is all you need in many case.
    Always make sure your crystal are accurate.
    BTW which PIC are you using?
    Mar 2007
    I'm using PIC16F88. I have 4 $55 and am using Manchester Encoding.
    Quote Originally Posted by oneohthree View Post
    So...
    oneofthree = jyi1 ???
    So...
    You are such a tease...!
    oneofthree or jyi1 or whatever your name is (we never got any) I told you before to start one data byte at the time. A complex program is hard to debug especially if there are serial com's.
    Also do not manchester encode the preambles. Only the data bytes and CRC or Checksum.
    USA - Arizona
    I looked back at some previous projects I have done with wireless comms. I have not used the Laipac modules, but have used the RFPICs and the Radiotronix modules.
    I have used 1200 baud with one preamble, two start-of-transmission identifiers (STX), and one end-of-transmission (ETX) identifier. The packet data is between these wrappers. In my experience the manchester coding did not help much with short messages.
    The only thing I was able to find was the following comments in my code:
    /* for wireless link, the "invert" option should not be used
    as this causes the transmitter to iddle on */
    My point is, have you tried your code with T2400 (as opposed to N2400)?
    Dec 2005
    Quote Originally Posted by languer View Post
    The Radiotronix RCR receivers are clones of the Wenshing/Laipac receivers. The only difference is they number the pins in reverse order. I think Radiotronix gets them from Cansec in China.
    Apr 2007
    T2400 doesn't really help.
  1. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 09:06
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 12:40
  3. Serial Wireless
    By mackrackit in forum mel PIC BASIC Pro
    Last Post: - 29th May 2007, 16:06
  4. Serial comm - are 2 wires for TX only enough?
    Last Post: - 30th August 2006, 03:23
  5. RS 485 wireless communication
    By Armadus in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 19:30
