Transmission works with wires but not always with wireless
Results 1 to 40 of 43
    Dec 2005
    Quote Originally Posted by jyi1 View Post
    If I were to run your code to test it would I code data0=0000001, data1=00000001, data2=00000101, data3=00001101 and then code data0=001000001, data1=00100001, data3=00100101, data3=00101101?
    You said you are sending 4 bits of data. My example was intended to show you how to send the 4 bits twice in two different ways. One way is "as is" in the lower 4 bits of wb; the other way is as the bitwise complement of the 4 data bits in the upper 4 bits of wb. Sending it in two forms allows us to check for errors on the receiving end.
    Assuming you want to send %1101...
    data=%1101
    wb=data
    wb=~wb
    wb=wb<<4        'bitwise complement %0010 in upper 4 bits
    wb=wb+data      'data "as is" in lower 4 bits
    The attached GIF shows the waveform for data=%1101.
    Last edited by dhouston; - 26th April 2007 at 13:18. Reason: Replaced the GIF - original had bit order reversed
  1. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 09:06
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 12:40
  3. Serial Wireless
    By mackrackit in forum mel PIC BASIC Pro
    Last Post: - 29th May 2007, 16:06
  4. Serial comm - are 2 wires for TX only enough?
    Last Post: - 30th August 2006, 03:23
  5. RS 485 wireless communication
    By Armadus in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 19:30
