Transmission works with wires but not always with wireless
Results 1 to 40 of 43
    AGC reduces the gain as the signal gets stronger......since I'm not measuring an absolute magnitude.
    Everything you said makes perfect sense to me. And it might also explain a few issues I've always had with a couple of my RF projects and lengthy/continuous packet transmissions getting dropped after a few seconds of transmitting. I'm going to try your 'pause between packets'/'making the packets smaller' idea and see what happens.
    I can understand that the issues you had might be module related. I never had any problems with FM modules and the ones I designed with the classic slicer approach (given that the proper transmission rules are followed). A good receiver should work 24/7 with no problem.
    It's not really 'problems' I have with the modules. They work fine for me, in bursts. I have a couple of project where one of my remotes acts sort of like a volume control and I have to continuously hold the transmit button down to get the receiver to change, takes about 15 seconds to run from one end to the other. About 3 or 4 seconds into holding the button, it craps out. If I release the button for less than a second and press it again, it'll work for another 3-4 seconds, then repeat. Again, no real problems, and I have a feeling that dhouston's hints earlier may solves this issue.
    Dec 2005
    That's somewhat analogous to dimming a lamp using an X-10 palmpad to send RF to a module that translates it to powerline commands to control the lamp module.
    X-10 uses the NEC protocol and the palmpad will send 32-bits continuously with each 32-bit burst preceded by a ~9ms/4.5ms lead-in and followed by a 40ms gap (so each code is ~105ms). It takes about 4-5 seconds to go from full on to full dim and it's very smooth.
    I conduct range tests (and RF tune receivers) by clamping a button down on a palmpad. The receiver operates smoothly for the several minutes I leave the transmitter clamped.
    IOW, I think you'll do better using the NEC protocol or some variation on it.
    One other thing to consider (which I alluded to earlier) is that you usually have at least two timelines. One is for the RF bitstream and one is for the action to be taken by the receiver (e.g. adjust volume or brightness). Things will be smoother if the end action can finish during the gap between code bursts. That way the receiver is ready to capture the next burst(s) and act on it (them).
    The NEC protocol (or variations of it) is the most popular (and oldest) protocol used for IR control of AV gear. If it has been so successful there, it makes sense to me to use it in similar low data rate RF applications.
    Dec 2005
    Agreed - but these are $5 (retail at Mouser Electronics) superregenerative ASK receivers with a maximum data rate of 4800bps.
    Dec 2005
    Almost all of my experience is with these specific superregenerative ASK receivers (at various frequencies) or with very similar superregenerative receivers. My suggestions may not apply if you're using more sophisticated receivers (e.g. superheterodyne) or FSK. Most of my applications send/receive 2-3 payload bytes. I think a wireless RS232 link and manchester encoding is overly complicated for such simple needs. If there's a need to send lengthy text or data streams, a superheterodyne or FSK receiver and a wireless RS232 link may make more sense.
    I cited the following web page earlier in the thread.You can see the effects of AGC on the initial pulse in the top trace of the first 'scope screenshot. The slope is from the AGC reacting to the wide pulse. You can see the slope starting in the other direction after the pulse ends. If you look a a lot of 'scope screenshots you'll see the same (less pronounced) effect even between the data pulses and see more pronounced differences between a closely spaced series of 0-bit (narrow space) versus 1-bit (wider space). Of course, it's affected by the absolute pulse space widths as well.
    The bottom picture is of a signal captured as a .WAV file with a soundcard. You can see that it's more difficult to discern a signal when it has no pronounced initial pulse to set the AGC. In this case, it's the signal sent by a Pronto touchscreen to a Philips RF extender. The three copies of the preamble contain information to address a specific RF extender and set its carrier frequency, etc. which must precede the actual IR code the extender is meant to relay. Philips doesn't use a superregenerative reveiver and they take other steps to improve reception (double modulation) but the picture illustrates the weaknesses of using no preamble or a narrow lead-in pulse with a superregenerative receiver.
    Thumbs up REG: ISM band and the WMTS band
    Any idea or estimation that are available towards the usage of the ISM band (2.4Ghz to 2.48Ghz) and the WMTS (Wireless medical telemetry service) band ( 608MHZ to 614MHZ, 1395MHZ to 1400MHZ) in the next coming decade for the purpose of the wireless communication implementation.
    It would be really great if any info available towards the same is linked to me, [email protected].
    Thank you.
  1. Wireless Tachometer - Design Help
    By DanPBP in forum Off Topic
    Last Post: - 3rd May 2009, 10:06
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 13:40
  3. Serial Wireless
    By mackrackit in forum mel PIC BASIC Pro
    Last Post: - 29th May 2007, 17:06
  4. Serial comm - are 2 wires for TX only enough?
    Last Post: - 30th August 2006, 04:23
  5. RS 485 wireless communication
    By Armadus in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 20:30
