Write and Read from eeprom
Results 1 to 24 of 24
    Yassou Niko!
    If the power is taken before the Write commands, then it is possible to loose the values. When do you power off the device?
    Jun 2006
    Yassou Niko!
    Geiasou Giannh (ta agglika mou einai xalia)
    I turn off the power after enough (>30 sec) time when change the value
    Time is not the most critical point. If the program never makes it to the Write commands, then it sure will never store the values to EEPROM.
    I had a similar problem and fixed it by using two variables. Do not know why this worked, but I have used this routine for some time now.
    cnt var byte
    Pb1	var word
    Pset    var word
    READ 0,Pset.BYTE0
    READ 1,Pset.BYTE1
    Pb1 = Pset
    C_P:
    		for cnt = 1 to 1
    		Pb1=Pb1+1
    		WRITE 0,Pb1.BYTE0
    		WRITE 1,Pb1.BYTE1
    		READ 0,Pset.BYTE0
    		READ 1,Pset.BYTE1
    		next
    Maybe all you need is the count routine to ensure that the data is being written?
    Jun 2006
    I have 4 routines to write and read
    Jun 2006
    Need to add the : Include "Modedefs.Bas" ;
    That would do it. Was scratching my head...
    Jun 2007
    Default read write to eeprom
    hello ya all,
    I have been at this for 3 days and nights now, i give up, I need help.
    Its simple in the pbp manual and from what Ive read in this forum, but to no luck. heres the details, not in the exact order
    pbp 2.47
    Include "modedefs.bas" ' is included
    DISABLE ' to turn off interupts even though i never hae used them
    TRISA = %11011
    TRISB = %11011011
    The problem is somtimes it works and somtimes it dosn't. When I read back the data after i write it, it reads correct. but after Ive turned it off and back on it comes up with weird numbers, random numbers. I send it to and lcd through serout2, and also receive a command or two. but I dont think the problem is there because other data shows up fine. the exact full code will be down below, but for now to point out where I think the problem is.
    WRITEIT:
    WRITE 0,T0
    READ 0,T0
    WRITE 1,T1
    READ 1,T1
    WRITE 2,P0
    READ 2,P0
    WRITE 3,P1
    READ 3,P1
    WRITE 4,C0
    READ 4,C0
    WRITE 5,C1
    READ 5,C1
    If my problem is somewhere else then Please point it out, cause I have tried everything. I am not one to give up easy, so for me to be here asking for help is rare. I am not an expert at pbp, but I do my best and can do almost everything I set out to do. here is the rest of my code
    Include "modedefs.bas" ' Include serial modes
    TRISA = %11011
    TRISB = %11011011
    '--------------------------DECLARES------------------------------
    PERCENT VAR BYTE
    TOTAL VAR WORD
    CAMBIO VAR WORD
    PREMIOS VAR WORD
    TT VAR WORD
    PP VAR WORD
    CC VAR WORD
    COUNTING VAR BYTE
    AMOUNT VAR BYTE
    MAC VAR BYTE
    DIP1 VAR BYTE
    DIP2 VAR BYTE
    DIP3 VAR BYTE
    DONE VAR BYTE
    COINOUT VAR PORTB.0
    COININ VAR PORTB.1
    MOTOR VAR PORTB.2
    LLAVE VAR PORTB.3
    BUTTON1 VAR PORTB.4
    COUNTER VAR PORTB.5
    A VAR WORD
    C0 VAR CAMBIO.BYTE0
    C1 VAR CAMBIO.BYTE1
    T0 VAR TOTAL.byte0
    T1 VAR TOTAL.byte1
    P0 VAR PREMIOS.BYTE0
    P1 VAR PREMIOS.BYTE1
    X VAR BYTE
    '-------------------------------SETUP-----------------------------
    counter=0
    motor=0
    DONE=0
    '----------------------------turn off interupts-------------------
    DISABLE
    '-----------------------------get data-----------------------------
    READ 0,T0
    READ 1,T1
    READ 2,P0
    READ 3,P1
    READ 4,C0
    READ 5,C1
    READ 6,MAC
    PAUSE 500
    AMOUNT=100
    COUNTING=0
    '----------------------------DIP SETUP-----------------------------
    DIP1=PORTA.0
    IF DIP1=0 THEN
    DIP1=40
    DIP1=20
    DIP2=PORTA.1
    IF DIP2=0 THEN
    DIP2=20
    DIP2=10
    DIP3=PORTB.7
    IF DIP3=0 THEN
    DIP3=10
    DIP3=5
    IF PORTA.4=0 THEN
    AMOUNT=25
    AMOUNT=100
    PERCENT=DIP1+DIP2+DIP3
    IF PERCENT=70 THEN PERCENT=100
    IF BUTTON1 = 0 THEN BOR
    '--------------------------------MAIN LOOP---------------------------
    LOOP:
    IF COININ = 1 THEN COUNT1COIN
    IF COINout = 1 THEN COINOUT100
    IF PORTB.6 = 1 THEN LLA2
    IF LLAVE = 1 THEN LLAVE1
    IF BUTTON1 = 0 THEN SACAR
    GOTO LOOP
    '-------------------------LLAVERO CONNECTED--------------------------
    LLA2:
    PAUSE 500
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO BORRAR
    '--------------------------CONTAR 1 MONEDA---------------------------
    COUNT1COIN:
    PAUSE 20
    IF COININ=1 THEN COUNT1COIN
    TOTAL=TOTAL+1
    GOSUB WRITEIT
    GOTO LOOP
    '----------------------CONTAR 1 MONEDA SALIENDO----------------------
    COINOUT100:
    PREMIOS=PREMIOS+1
    TOTAL=TOTAL-1
    GOSUB WRITEIT
    GOTO LOOP
    '-------------------------CONTAR 1 A CONTADOR------------------------
    CNT:
    COUNTER=1
    PAUSE 40
    COUNTER=0
    PAUSE 50
    '------------------------EL LLAVE DEL CLIENTE------------------------
    LLAVE1:
    PAUSE 100
    IF LLAVE=1 THEN LLAVE1
    IF CAMBIO +AMOUNT > (TOTAL/PERCENT)*100 THEN LOOP
    COUNTING=0
    MOTOR=1
    COUNT100:
    IF COINOUT=1 THEN COUNT100WAIT
    GOTO COUNT100
    COUNT100WAIT:
    PAUSE 5
    IF COINOUT=0 THEN COUNT100DONE
    GOTO COUNT100WAIT
    COUNT100DONE:
    COUNTING=COUNTING+1
    TOTAL=TOTAL-1
    CAMBIO=CAMBIO+1
    GOSUB WRITEIT
    IF COUNTING=AMOUNT THEN
    motor=0
    gosub cnt
    PAUSE 300
    GOTO LOOP
    gosub cnt
    GOTO COUNT100
    '-----------------------------GUARDAR INFO--------------------------
    WRITEIT:
    WRITE 0,T0
    READ 0,T0
    WRITE 1,T1
    READ 1,T1
    WRITE 2,P0
    READ 2,P0
    WRITE 3,P1
    READ 3,P1
    WRITE 4,C0
    READ 4,C0
    WRITE 5,C1
    READ 5,C1
    'PARA NO BORRAR CON EL BUTTONES AL MENOS QUE NO TIENE UN # DE MAC
    BOR:
    IF MAC > 251 THEN
    GOTO BORRAR1
    GOTO LOOP
    '----------------------------BORRAR INFO---------------------------
    BORRAR:
    SERIN2 PORTA.3,16780, 500,BORRAR,[WAIT ("CB"),DEC1 DONE]
    IF DONE=1 THEN BORRAR1
    IF DONE=0 THEN MAC1
    GOTO BORRAR
    BORRAR1:
    TOTAL=0
    PREMIOS=0
    CAMBIO=0
    GOSUB WRITEIT
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO LOOP
    '----------------------MANDAR LA INFO AL LLAVERO-------------------
    INFO:
    A = TOTAL * 100 'A is temporary storage of computation
    A = DIV32 PERCENT 'using DIV32... B can be any integer up to 65534
    A = A / 100 'final result is placed in variable A as an integer... any
    PREMIOS=A
    SEROUT2 PORTA.2,16780,["M",DEC3 MAC]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["T",DEC5 TOTAL]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["P",DEC5 PREMIOS]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["%",DEC3 PERCENT]
    PAUSE 100
    SEROUT2 PORTA.2,16780,["S",DEC5 CAMBIO]
    '-----------------------GRABAR EL # DE MAC-------------------------
    MAC1:
    serin2 PORTA.3,16780, MAC1,[WAIT ("M"),DEC3 MAC]
    WRITE 6,MAC
    READ 6,MAC
    FOR X=1 TO 5
    GOSUB INFO
    NEXT X
    GOTO BORRAR
    '------------------------SACAR EL GANACIAS-------------------------
    SACAR:
    PAUSE 100
    IF BUTTON1=0 THEN SACAR
    IF TOTAL < 100 THEN LOOP
    MOTOR=1
    COUNTING=0
    CAMOUNT:
    IF COINOUT=1 THEN CAMOUNTWAIT
    GOTO CAMOUNT
    CAMOUNTWAIT:
    PAUSE 5
    IF COINOUT=0 THEN CDONE
    GOTO CAMOUNTWAIT
    CDONE:
    COUNTING=COUNTING+1
    TOTAL=TOTAL-1
    GOSUB WRITEIT
    IF COUNTING=100 THEN
    MOTOR=0
    PAUSE 300
    GOTO LOOP
    GOTO CAMOUNT
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
