Write and Read from eeprom
Results 1 to 24 of 24
    Jun 2006
    Default Write and Read from eeprom
    I have the below code (one part of code).
    My problem is when turn off the power and after turn on again , don't save the value P in the eeprom always.Why;
    I use 16f88
        P VAR WORD	          'value of the divider
        FLAG VAR BYTE
        READ 3,FLAG
        IF FLAG = 55 THEN
        READ 1,P.BYTE0        ' Divider
        READ 2,P.BYTE1
    	P= 256	        	  ' value of the divider
    '************************** CHOICE OF THE DIVIDER ***********************
    PREDIV:
    	LCDOUT $FE,1,"*    DIVIDER   *"
    	LCDOUT $FE,$C0,"     P = ",#P
    LOOP:
        BUTTON PLUS,0,10,5,B1,1,PICK	    ' Goes to PICK if press the button
    	BUTTON BMENU,0,255,0,B4,1,MEN
    	PAUSE 100
    	GOTO LOOP
    PICK:
        IND = IND + 1
    	IF IND< 9 THEN CHOIX
    	IND= 0
    	GOTO CHOIX
    CHOIX:
        LOOKUP2 IND,[1,10,16,32,40,64,80,128,256],P
    	WRITE 3 , 55
    	WRITE 1 , P.BYTE0      	            ' SAVE The VALUE OF P
    	WRITE 2 , P.BYTE1
        PAUSE 100
    	GOTO MAIN
    Yassou Niko!
    If the power is taken before the Write commands, then it is possible to loose the values. When do you power off the device?
    Jun 2006
    Yassou Niko!
    Geiasou Giannh (ta agglika mou einai xalia)
    I turn off the power after enough (>30 sec) time when change the value
    Time is not the most critical point. If the program never makes it to the Write commands, then it sure will never store the values to EEPROM.
    I had a similar problem and fixed it by using two variables. Do not know why this worked, but I have used this routine for some time now.
    cnt var byte
    Pb1	var word
    Pset    var word
    READ 0,Pset.BYTE0
    READ 1,Pset.BYTE1
    Pb1 = Pset
    C_P:
    		for cnt = 1 to 1
    		Pb1=Pb1+1
    		WRITE 0,Pb1.BYTE0
    		WRITE 1,Pb1.BYTE1
    		READ 0,Pset.BYTE0
    		READ 1,Pset.BYTE1
    		next
    Maybe all you need is the count routine to ensure that the data is being written?
    Jun 2006
    I have 4 routines to write and read
    Jun 2006
    Need to add the : Include "Modedefs.Bas" ;
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 14:06
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
