Write and Read from eeprom
Results 1 to 24 of 24
    Hangover, Germany
    Exclamation
    What happens, if you switch off the power ?
    Maybe the code just think, the switch is pressed and try to write to the eeprom - while power is falling...
    Jun 2007
    Default BigWumpus's was right !!!
    Yep that is my problem.
    if I take out the "write" it saves fine
    COINOUT100:
    PREMIOS=PREMIOS+1:if total > 0 then TOTAL=TOTAL-1
    :GOTO LOOP 'GOSUB WRITEIT
    So I did a little checking and the machine I'm interfacing to sends several signals as its lossing power, somthing to do with a cheap design cause theres no other reason. I will buy a scope to see if its a specific signal or just random crap. I think its just random crap cuase if I hook a anolog counter to it, it counts up to differrent amounts somtime 3 somtimes up to 6.
    As to my messy code design, I'm sorry skimask. I have never had any training of any kind nor has anyone ever showed me how to write decent code. This is the first time in 15 years I have ever been on a forum for basic, quickbasic, visual basic, or pic basic pro.
    I am one to learn things on my own, but as you pointed out (at my messy code) that type of learning has its problems. I do my best
    I will continue this forum experience, Its al right. thank you all for your help with this one.
    And thank you BigWumpus for figuring this one out for me......
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
