Round the clock
Results 1 to 28 of 28
Thread: Round the clock
    Default Re: Round the clock
    Normally you won't count to 24 but up to 23:59. But I have missed the point of -/+1 here.
    Jan 2013
    Hi I,
    My actual system uses 0 to 3581 steps, but that's complicating things This is why I used the clock analogy. And yes, it is 0 to 23:59, but again this is complicating things, as there are 60 minutes/hour. So I'll use 0 to 11.
    The mechanics of my system: A motor moves the pointer to the incoming data, so if it is pointing to 3 and data says 4 then it moves cwise till it matches. The motor moves quickly, so as it comes towards 4 it needs to switch off the motor, before it matches, so I added a deadband, which gives data -1 and +1, where no power to the motor within this band. Now say the pointer is at 3 and data says 5 the pointer is moves cwise and switches the power off at 4. In this example, this looks coarse, but in reality, it is much finer.
    I hope this clarifies things.
    C.
    Try this:
    Position    VAR WORD
    Target      VAR WORD
    Distance    VAR WORD
    Position = 1234
        HSEROUT[13, "You're at position: ", DEC Position, 13]
        HSEROUT["Enter new target: ",13]
        HSERIN[DEC Target]
        ' Actual calculation starts here.
        ' When done the variable Distance contains the
        ' number of "ticks" to target in two's complement format.
        Distance = Target - Position
        IF Distance.15 = 0 THEN             ' Distance is positive
            If Distance > 1790 THEN
                Distance = Distance - 3580
            Endif
        IF Distance.15 = 1 THEN              ' Distance is negative
            IF ABS Distance > 1790 THEN
                Distance = Distance + 3580
        ' End of calculation, result now in Distance.
    Done:
            HSEROUT["CCW "]
            HSEROUT["CW "]
        HSEROUT[DEC ABS Distance, " ticks.", 13]
        Position = Target
    Goto Main
    Jan 2013
    Hi H,
    Thank you, I will try it and let you know what happens. I'm a bit slow understanding code though
    Will you annotate where the DEADBAND is in your code please?
    C.
    There's no deadband but it's easy enough to add that after the actual calculation, before you decide to move or not
    IF ABS Distance > Deadband THEN
       ' Make the move
      ' Sit tight
    Jan 2013
    Thanks H, C
    Jan 2013
       ' Make the move
      ' Sit tight
    Hi Henrik
    Does this also work for 'IF ABS Distance > Deadband THEN' and 'IF ABS Distance < Deadband THEN' at the change from 11 to 0 and 0 to 11?
    C.
    Have you tried it?
    Using your numbers with 3580 ticks around the circle:
    If you're moving from 0 to 11 distance is +11.
    If you're moving from 11 to 0 distance is -11.
    In both cases the ABSolute value of distance is 11. If you have deadband set to 1 then you'll move because distance is larger than deadband.
    If you're moving from 11 to 12 distance is +1.
    If you're moving from 12 to 11 distance is -1.
    In both cases the ABSolute value of distance is 1. If you have deadband set to 1 then you won't move because distance is not larger than deadband.
  1. DT_INT Vs ASM - Round 1
    Last Post: - 27th January 2013, 22:33
  2. How to round number using integer only
    By Yvesmazzon in forum Code Examples
    Last Post: - 6th March 2011, 14:37
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. Clock
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 03:23
  5. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
