Round the clock
Results 1 to 28 of 28
Thread: Round the clock
    Jan 2013
    Default Re: Round the clock
    Hi H,
    Thank you, I will try it and let you know what happens. I'm a bit slow understanding code though
    Will you annotate where the DEADBAND is in your code please?
    C.
    There's no deadband but it's easy enough to add that after the actual calculation, before you decide to move or not
    IF ABS Distance > Deadband THEN
       ' Make the move
      ' Sit tight
    Jan 2013
    Thanks H, C
    Jan 2013
       ' Make the move
      ' Sit tight
    Hi Henrik
    Does this also work for 'IF ABS Distance > Deadband THEN' and 'IF ABS Distance < Deadband THEN' at the change from 11 to 0 and 0 to 11?
    C.
    Have you tried it?
    Using your numbers with 3580 ticks around the circle:
    If you're moving from 0 to 11 distance is +11.
    If you're moving from 11 to 0 distance is -11.
    In both cases the ABSolute value of distance is 11. If you have deadband set to 1 then you'll move because distance is larger than deadband.
    If you're moving from 11 to 12 distance is +1.
    If you're moving from 12 to 11 distance is -1.
    In both cases the ABSolute value of distance is 1. If you have deadband set to 1 then you won't move because distance is not larger than deadband.
    Jan 2013
    Have you tried it?
    Hi Henrik,
    My system is actually 0 to 3581, so 3582 ticks/circle. I used the 0 to 11 clock face to simplify my question, so actually 11 to 0 is similar to 3283 to 0.
    This is an interesting solution, if I can use it. At the moment I'm trying to unravel a pile if spaghetti with my existing program.
    I have to convert it for use with the Oshonsoft system, while learning about ABS, and the ????????.15 variable. I'm not sure if Oshonsoft supports ABS, but I assume it can be got round in some way.
    I'll let you know once I get it running, thanks.
    C.
    PBP doesn't have signed 16-bit (WORD) variables so the distance.15 is simply a way to determine if the value is negative. The equivalent code, if you have signed variables, would be:
        Distance = Target - Position
        IF Distance > 1790 THEN
           Distance = Distance - 3580
        Endif
        IF Distance < -1790 THEN
           Distance = Distance + 3580
    Jan 2013
    Hi Henrik,
    As mentioned my system has 3582 tick/rev, so is the 3580 in the last post correct?
    I don't think Oshonsoft supports negative values, but I'll check.
    Thanks, C.
  1. DT_INT Vs ASM - Round 1
    Last Post: - 27th January 2013, 22:33
  2. How to round number using integer only
    By Yvesmazzon in forum Code Examples
    Last Post: - 6th March 2011, 14:37
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. Clock
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 03:23
  5. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
