Round the clock
Results 1 to 28 of 28
Thread: Round the clock
    Sep 2010
    Las Vegas, NV
    Default Re: Round the clock
    Is it the MODulus operation you're having problems with or its implementation?
    I had to get a pencil and paper out and do some modulus operations before my extremely thick skull was pierced enough to see how the modulus operator worked. Once understood it's pretty neat. Now if I could only get the */ thingy figured out.
    Jan 2013
    Quote Originally Posted by AvionicsMaster1 View Post
    Hi A,
    I've had quite a bit of MODulus explained to me since it cropped up a day or two ago, and I'm beggining to see the light. It does appear to be the right way to go.
    What problems are you having with * and /?
    C.
    Jan 2013
    The program itself is fine at the 12 to 0 changeover, but with a DEADBAND, it complicates things.
    Ioannis suggested Modulus also using a 24Hr clock.
    After trying to get to know Modulus, for a while, I can only guess, that it won't correct my problem. The problem is a DEADBAND, so 'say' 3 with a DEADBAND of 1 would be 2 to 4. At o it will be -1 to 1. I don't get the impression that Modulus works with minus numbers.
    I experimented with the 24 hour clock, and as the clock goes round and round, eventually it will be 24 then 0 again, so a similar problem. I finally only use 24Hr for a small section around 12 or 0. then revert back to 12 hour, this works fine.
    Thanks for all suggestions, C.
    Normally you won't count to 24 but up to 23:59. But I have missed the point of -/+1 here.
    Jan 2013
    Hi I,
    My actual system uses 0 to 3581 steps, but that's complicating things This is why I used the clock analogy. And yes, it is 0 to 23:59, but again this is complicating things, as there are 60 minutes/hour. So I'll use 0 to 11.
    The mechanics of my system: A motor moves the pointer to the incoming data, so if it is pointing to 3 and data says 4 then it moves cwise till it matches. The motor moves quickly, so as it comes towards 4 it needs to switch off the motor, before it matches, so I added a deadband, which gives data -1 and +1, where no power to the motor within this band. Now say the pointer is at 3 and data says 5 the pointer is moves cwise and switches the power off at 4. In this example, this looks coarse, but in reality, it is much finer.
    I hope this clarifies things.
    C.
    Try this:
    Position    VAR WORD
    Target      VAR WORD
    Distance    VAR WORD
    Position = 1234
        HSEROUT[13, "You're at position: ", DEC Position, 13]
        HSEROUT["Enter new target: ",13]
        HSERIN[DEC Target]
        ' Actual calculation starts here.
        ' When done the variable Distance contains the
        ' number of "ticks" to target in two's complement format.
        Distance = Target - Position
        IF Distance.15 = 0 THEN             ' Distance is positive
            If Distance > 1790 THEN
                Distance = Distance - 3580
            Endif
        IF Distance.15 = 1 THEN              ' Distance is negative
            IF ABS Distance > 1790 THEN
                Distance = Distance + 3580
        ' End of calculation, result now in Distance.
    Done:
            HSEROUT["CCW "]
            HSEROUT["CW "]
        HSEROUT[DEC ABS Distance, " ticks.", 13]
        Position = Target
    Goto Main
    Jan 2013
    Hi H,
    Thank you, I will try it and let you know what happens. I'm a bit slow understanding code though
    Will you annotate where the DEADBAND is in your code please?
    C.
  1. DT_INT Vs ASM - Round 1
    Last Post: - 27th January 2013, 22:33
  2. How to round number using integer only
    By Yvesmazzon in forum Code Examples
    Last Post: - 6th March 2011, 14:37
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. Clock
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 03:23
  5. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
