Round the clock
Results 1 to 28 of 28
Thread: Round the clock
    Jan 2013
    Default Re: Round the clock
    Modulus division. You divide by 12 and keep the as a result the integer remainder of the division.
    So 23.00 h mod 12 gives remaider 11, exactly what 23 at 12h basis is.
    Hi I,
    I'm not so good at Maths, so please make allowances
    I have to read instructions a number of times to 'get it'. In this line is there a word missing? [You divide by 12 and keep the=== as a result the integer remainder of the division.]
    As mentioned, I'm programming a PIC and I just looked at the Oshonsoft manual, here is a paragraph:
    Five arithmetic operations (+, -, *, /, MOD) are available for integer data types. MOD operation is not applicable for Single data type variables. The compiler is able to compile all possible complex arithmetic expressions, including those containing math functions and user defined functions. For example:
    Dim i As Word
    Dim j As Word
    Dim x As Word
    i = 123
    j = i * 234
    x = 2
    x = (j * x - 12345) / (i + x)
    From my reading, and as I'm using SINGLEs, this means I can't use MOD. If so is there another way? (SINGLEs allow 0.0000000)
    C.
    I have not used the Oshonsoft compiler yet, although I have it.
    But nothing bothers you to use a Word variable instead of the Single.
    I wrote my post in succesive interruptions because of phone calls and other tasks, so yes, the word "the" should be deleted.
    Jan 2013
    Hi I,
    Oshonsoft is a good simulator for me, although it does have faults.
    I need the SINGLE in the equation as it can cope with precision 0.0000000 calculations, WORD won't work.
    C.
    Apr 2011
    Welches, Oregon
    I do not follow the conversation well enough to speak in context, but in doing a similar thing I found the solution to calculate direction and distance separately; then, once I'd accurately calculated these, dump off those variables to a routine that "swung the needle". I did not need to worry about "round" however as I was programming to mimic analog gauges.
    Last, to simulate MOD subtract the integer value from the single value - that decimal portion which remains...
    Jan 2013
    Quote Originally Posted by Amoque View Post
    Hi A,
    Here's another explanation, again using the clock:
    1/ The HAND is at 3. Input FACE 5. HAND<FACE = cwise. HAND moves and counts. HAND=4. HAND<FACE=cwise. HAND moves and counts. HAND=5. HAND=FACE =BRAKE.
    2/ The HAND is at 12. Input FACE=1 HAND>FACE = ccwise NOT CORRECT.
    I want FACE to cover FACE+1 and FACE-1.
    3/ The HAND is at 12. Input FACE=1 Now FACE-1= -1.
    This is difficult for me to understand.
    I am also trying to understand the MOD suggestions. I will need to check the program to see if I can use MOD, as I get to understand it more.
    Thanks. C.
    C.
    Sep 2010
    Las Vegas, NV
    Is it the MODulus operation you're having problems with or its implementation?
    I had to get a pencil and paper out and do some modulus operations before my extremely thick skull was pierced enough to see how the modulus operator worked. Once understood it's pretty neat. Now if I could only get the */ thingy figured out.
    Jan 2013
    Quote Originally Posted by AvionicsMaster1 View Post
    Hi A,
    I've had quite a bit of MODulus explained to me since it cropped up a day or two ago, and I'm beggining to see the light. It does appear to be the right way to go.
    What problems are you having with * and /?
    C.
  1. DT_INT Vs ASM - Round 1
    Last Post: - 27th January 2013, 22:33
  2. How to round number using integer only
    By Yvesmazzon in forum Code Examples
    Last Post: - 6th March 2011, 14:37
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. Clock
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 03:23
  5. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
