Upon more digging and testing, it appears this problem may have been caused by the fact that my PBP3 install was not "activated" yet. I hopefully will get activation key Monday and will see if this solves the problem. Till then?
Hello Everyone,
I am trying out FL IDE and get the same thing as in this FL1_6_0_0.pdf. The Code compiles fine inn the MCSEX IDE.
CharlieM
Using PBP3
MCSPX
Hi Norm,
From what I can tell the paths are correct. The Path is C:\Users\Charlie\ Documents\PBP Projects. The project compiles fine using MCS.
CharlieM
Using PBP3
MCSPX
Thanks for writing such a nice editor, Norm.
I'm seeing this behavior with 2.0.0.0:
Source path is C:\Users\dlkerl\picstuff\oven
The path is identical in the error message, but the file name in the source directory only has one 'R': OVEN_V0_3.ER (empty file)
MCS launches PBP with no problems (PBP 2.45)
Unrelated question: Is it possible to stop automatic indentation of labels in ASM blocks?
Thanks-Dan
Hey Norm,
Could you make available the pre PBP3 version of FineLine. I am still having trouble on machines that do not have PBP3 with the current FineLine.
The .ER file is the PBP compiler text to assy error file.
The .ERR file is the MPSAM assy to hex error file.
Possibly the "Users" in C:\Users\dlkerl\picstuff\oven is throwing FL off?
Try compiling with your program file in a non Users directory.
Yes I should be able to disable all auto indent of assy lines if that would be best?
Anyone familiar with assy please advise.
I am presently finishing up the pre beta of FL 2.1.0.0 with several fixes.
Norm
