Averaging AtoD samples
Results 1 to 40 of 40
    The first 10 would be tossed but the second 10 would not because now the pairs are 10,10,11...
    Mar 2009
    Aah...ok, gotcha.
    Actually my example 'data series' wasn't a good one, as the data values would actually be in the hundreds (vs units which I used), which allows percentages to be used.
    So, assuming a series of data coming into a variable called 'sample'...
    ' compare a pair called value & value2 from the incoming 'sample'
    value = sample     '
    upper_window = value2+(value2*4/100) 'create a window 4% above previous sample
    lower_window = value2-(value2*4/100)  'create a value 4% below previous sample
    if (value>= lower_window) AND (value <= upper_window) then incoming 'sample is within 'allowable error window'?
    gosub average 'goto averaging routine
    value2 = value1
    etc
    would something like the above work?#
    Edit: Just seen your post/link scalerobotics - off to have reader's digestion! (& yes, I did a search but I guess my keywords weren't erhm key)
    Mar 2009
    ok, so scalerobotic's link to Melanie's 'sorting numbers' article, is exactly what I need, so I'm trying to get the thing to work.
    i've basically got a small array that a prepopulate with some random numbers.
    @ __CONFIG _FCMEN_OFF & _HS_OSC & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF
    DEFINE  OSC 20          ' set Oscillator at 20Mhz.
    DEFINE  NO_CLRWDT 1   ' PBP doesn't clear WDT automatically
    DEFINE HSER_CLROERR 1
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 129 ' set USART to 9600 baud  @20Mhz
        CounterA var Byte
        DataA var Byte
        RawData var Byte [6]
        Averaged var byte
        hserout [27,91,72]          'home cursor
        hserout [27,91,50,74]       'clear screen
        RawData[0]  = 25
        RawData[1]  = 27
        RawData[2]  = 32
        RawData[3]  = 30
        RawData[4]  = 34
        RawData[5]  = 33
        hserout ["before....", 13, 10]
        hserout [dec rawdata[0],13,10]
        hserout [dec rawdata[1],13,10]
        hserout [dec rawdata[2],13,10]
        hserout [dec rawdata[3],13,10]
        hserout [dec rawdata[4],13,10]
        hserout [dec rawdata[5],13,10]
        hserout [13,10]
        hserout [13,10]
        CounterA =0
        gosub SortArray
        gosub Average_data
        hserout ["after....", 13, 10]
        hserout ["averaged = ", dec averaged,13,10]
        goto end1
    Average_data:
        hserout [dec rawData[2]," + ", dec rawData[3], 13,10]
        Averaged = (rawData[2]+rawData[3])/2    ' average the middle two of 6 ongoing samples
    SortArray:
    SortLoop:
        If RawData(CounterA+1) < RawData(CounterA) then
            DataA=RawData(CounterA)
            RawData(CounterA)=RawData(CounterA+1)
            RawData(CounterA+1+0)=DataA
            If CounterA > 0 then CounterA=CounterA-2
        CounterA=CounterA+1
        If CounterA < 5 then goto SortLoop
        end1:
    here's my screen output (I average the middle two numbers Rawdata[2] & RawData[3] )....
    before....
    25
    27
    32
    30
    34
    33
    after....
    6
    25
    27
    30
    32
    33
    averaged = 31
    It all works (ie sorts & averages correctly) - but where on earth has the number 6 in the sorted numbers come from? (there was no number six in the original array - also, whatever number I place in that array position RawData[4] comes out sorted as 6!?!!)
    Edit: Ok, think I've stumbled on the issue - it seems to be related to my array declaration ....because when I use RawData var Byte [8] ...everything works.
    So why can't I declare an array 5 bytes 'deep'? ie RawData var byte [5] ???
    May 2008
    Italy
    Check out the sorting routine because it doesn't work. The first number should be 25, while the last number should be 34 not 33.
    Also your average is not correct, since 27 + 30 / 2 = 28.5 (28 as integer) not 31
    Very likely the error comes from the wrong sorting.
    Cheers
    Al.
    I suppose that you corrected the array definition from[6] to [5].
    And then the check in the program:
    to this:
    If CounterA < 4 then goto SortLoop
    Mar 2009
    Guy - what can I say .....I initially used random 1-6 for my numbers in the array & it sorted them & averaged them fine! (ie 1,2,3,4,5,6 was the screen output!)
    I'm puzzled why my screen output posted above doesn't look like it's working (for either the sorting or the averaging!! lol) - it was late ...that's my lame excuse for not picking up on that! The 'sorting' part of the code was a direct lift from Melanie's article.
    I'm at work now (don't tell my boss!) , so will revisit this tonight.
    Mar 2009
    Ok, the thread title really ought to be called stripping out erroneous samples & then averaging the leftovers (vs averaging data which includes erroneous samples), I've revisited my earlier problem
    ANSEL       =  0
    ANSELH     =  0
        CounterA            var Byte    'A counter for sorting out the erroneous data
        DataA               var word    'A Variable used in sorting the numbers in the array
        RawData             var word [6] 'This is the RawData gojng into the array
        Averaged            var word     'This is used to get the average.
        top:
        RawData[0]  = 300
        RawData[1]  = 100
        RawData[2]  = 200
        RawData[3]  = 600
        RawData[4]  = 400
        RawData[5]  = 500
        pause 250
       next1:
        hserout [13,10]
        hserout [13,10]
        pause 300
        hserout [13,10]
        hserout [13,10]
        hserout [13,10]
        pause 2000
        CounterA =0
        gosub SortArray
        gosub Average_data
        hserout [13,10]
        hserout [13,10]
        hserout ["therefore, middle two samples are ", dec rawData[2]," + ", dec rawData[3], 13,10]
        hserout [13,10]
        hserout ["averaged middle two samples = ", dec averaged,13,10]
        pause 3000
        goto top
    Average_data:
        Averaged = (rawData[2]+rawData[3])/2    ' average the middle two of 6 samples
    SortArray:
    SortLoop:
        CounterA=CounterA+1
    And it works (basically, the code throws away all but the middle two samples of six & averages those two - ideal if your input data is all over the place.,...eg comparator counts etc!)...
    before....
    300
    100
    200
    600
    400
    500
    after....
    100
    200
    300
    400
    500
    600
    therefore, middle two samples are 300 + 400
    averaged middle two samples = 350
    Or a more real world example (eg a comparator interrupt count jittering in or around the 200 count level but with one spurious/erroneous count of 400 in the 'sample of six' to get rid of)...
    before....
    199
    400
    200
    200
    199
    200
    after....
    199
    199
    200
    200
    200
    400
    therefore, middle two samples are 200 + 200
    averaged middle two samples = 200
    Not entirely sure what the problem was (I changed a few things at once & didn't retrace my steps!)
    May 2008
    Italy
    That's better!
    Cheers
    Al.
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 06:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 17:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 16:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 18:17
