Averaging AtoD samples
Results 1 to 40 of 40
    I suppose that you corrected the array definition from[6] to [5].
    And then the check in the program:
    If CounterA < 5 then goto SortLoop
    to this:
    If CounterA < 4 then goto SortLoop
    Mar 2009
    Guy - what can I say .....I initially used random 1-6 for my numbers in the array & it sorted them & averaged them fine! (ie 1,2,3,4,5,6 was the screen output!)
    I'm puzzled why my screen output posted above doesn't look like it's working (for either the sorting or the averaging!! lol) - it was late ...that's my lame excuse for not picking up on that! The 'sorting' part of the code was a direct lift from Melanie's article.
    I'm at work now (don't tell my boss!) , so will revisit this tonight.
    Mar 2009
    Ok, the thread title really ought to be called stripping out erroneous samples & then averaging the leftovers (vs averaging data which includes erroneous samples), I've revisited my earlier problem
    @ __CONFIG _FCMEN_OFF & _HS_OSC & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF
    DEFINE  OSC 20          ' set Oscillator at 20Mhz.
    DEFINE  NO_CLRWDT 1   ' PBP doesn't clear WDT automatically
    DEFINE HSER_CLROERR 1
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 129 ' set USART to 9600 baud  @20Mhz
    ANSEL       =  0
    ANSELH     =  0
        CounterA            var Byte    'A counter for sorting out the erroneous data
        DataA               var word    'A Variable used in sorting the numbers in the array
        RawData             var word [6] 'This is the RawData gojng into the array
        Averaged            var word     'This is used to get the average.
        top:
        RawData[0]  = 300
        RawData[1]  = 100
        RawData[2]  = 200
        RawData[3]  = 600
        RawData[4]  = 400
        RawData[5]  = 500
        pause 250
        hserout [27,91,72]          'home cursor
        hserout [27,91,50,74]      'clear screen
       next1:
        hserout [13,10]
        hserout [13,10]
        pause 300
        hserout ["before....", 13, 10]
        hserout [13,10]
        hserout [dec rawdata[0],13,10]
        hserout [dec rawdata[1],13,10]
        hserout [dec rawdata[2],13,10]
        hserout [dec rawdata[3],13,10]
        hserout [dec rawdata[4],13,10]
        hserout [dec rawdata[5],13,10]
        hserout [13,10]
        hserout [13,10]
        pause 2000
        CounterA =0
        gosub SortArray
        gosub Average_data
        hserout ["after....", 13, 10]
        hserout [13,10]
        hserout [13,10]
        hserout ["therefore, middle two samples are ", dec rawData[2]," + ", dec rawData[3], 13,10]
        hserout [13,10]
        hserout ["averaged middle two samples = ", dec averaged,13,10]
        pause 3000
        goto top
    Average_data:
        Averaged = (rawData[2]+rawData[3])/2    ' average the middle two of 6 samples
    SortArray:
    SortLoop:
        If RawData(CounterA+1) < RawData(CounterA) then
            DataA=RawData(CounterA)
            RawData(CounterA)=RawData(CounterA+1)
            RawData(CounterA+1+0)=DataA
            If CounterA > 0 then CounterA=CounterA-2
        CounterA=CounterA+1
    And it works (basically, the code throws away all but the middle two samples of six & averages those two - ideal if your input data is all over the place.,...eg comparator counts etc!)...
    before....
    300
    100
    200
    600
    400
    500
    after....
    100
    200
    300
    400
    500
    600
    therefore, middle two samples are 300 + 400
    averaged middle two samples = 350
    Or a more real world example (eg a comparator interrupt count jittering in or around the 200 count level but with one spurious/erroneous count of 400 in the 'sample of six' to get rid of)...
    before....
    199
    400
    200
    200
    199
    200
    after....
    199
    199
    200
    200
    200
    400
    therefore, middle two samples are 200 + 200
    averaged middle two samples = 200
    Not entirely sure what the problem was (I changed a few things at once & didn't retrace my steps!)
    May 2008
    Italy
    That's better!
    Cheers
    Al.
    Mar 2009
    Quote Originally Posted by aratti View Post
    That's better!
    Cheers
    Al.
    & thanks for offering up some help/support earlier!
    Oct 2010
    In a different application I used a "weighted Average" where no one sample could mangle the running average.
    This is the regurgitated conversion to PBP:
    I initialize the values and add new value to the stack and subtract off the old average, giving the new value 1/weight of effect
    I leave the running average in A2D counts to avoid rounding
    Must watch (Max value * number of samples) < 65000
    Weight var byte
    WeightedAve var word
    Ave var word
    WeightedCounts
    NewAve var word
    Count var word
    AveragingComplete var word
    Incoming var word ‘incoming value from a2d
    WeightedCounts=0
    Weight = 100
    AveragingComplete = 0
    Ave=0
    If Count=0 then WeightedCounts= incoming* Weight
    If Count=0 then Ave= incoming
    If Count < Weight then Count = Count + 1
    NewAve =(incoming+ WeightedCounts-Ave
    WeightedCounts= NewAve
    Ave= WeightedCounts/ Weight
    If Count = Weight then AveragingComplete = 1
    If Count = Weight then Display “Weighted Average” ‘lcd routine
    If Count < Weight then Display “building average” ‘lcd routine
    Mar 2009
    Quote Originally Posted by Plcguy View Post
    It must be cos I suck at maths, but I've read that a few times & it's not sinking in. Can I use an example here to how that works in practise. Let's say six AtoD Samples are taken....
    100
    99
    100
    101
    499
    100
    You said that your weighted average stops a spurious reading skewing the overall average...can you illustrate using those six samples how the 499 would be ignored?
    Many thanks!
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 06:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 17:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 16:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 18:17
