Averaging AtoD samples
Results 1 to 40 of 40
Threaded View
  1. #13
    Mar 2009
    Ok, the thread title really ought to be called stripping out erroneous samples & then averaging the leftovers (vs averaging data which includes erroneous samples), I've revisited my earlier problem
    @ __CONFIG _FCMEN_OFF & _HS_OSC & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF
    DEFINE  OSC 20          ' set Oscillator at 20Mhz.
    DEFINE  NO_CLRWDT 1   ' PBP doesn't clear WDT automatically
    DEFINE HSER_CLROERR 1
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 129 ' set USART to 9600 baud  @20Mhz
    ANSEL       =  0
    ANSELH     =  0
        CounterA            var Byte    'A counter for sorting out the erroneous data
        DataA               var word    'A Variable used in sorting the numbers in the array
        RawData             var word [6] 'This is the RawData gojng into the array
        Averaged            var word     'This is used to get the average.
        top:
        RawData[0]  = 300
        RawData[1]  = 100
        RawData[2]  = 200
        RawData[3]  = 600
        RawData[4]  = 400
        RawData[5]  = 500
        pause 250
        hserout [27,91,72]          'home cursor
        hserout [27,91,50,74]      'clear screen
       next1:
        hserout [13,10]
        hserout [13,10]
        pause 300
        hserout ["before....", 13, 10]
        hserout [13,10]
        hserout [dec rawdata[0],13,10]
        hserout [dec rawdata[1],13,10]
        hserout [dec rawdata[2],13,10]
        hserout [dec rawdata[3],13,10]
        hserout [dec rawdata[4],13,10]
        hserout [dec rawdata[5],13,10]
        hserout [13,10]
        hserout [13,10]
        pause 2000
        CounterA =0
        gosub SortArray
        gosub Average_data
        hserout ["after....", 13, 10]
        hserout [13,10]
        hserout [13,10]
        hserout ["therefore, middle two samples are ", dec rawData[2]," + ", dec rawData[3], 13,10]
        hserout [13,10]
        hserout ["averaged middle two samples = ", dec averaged,13,10]
        pause 3000
        goto top
    Average_data:
        Averaged = (rawData[2]+rawData[3])/2    ' average the middle two of 6 samples
    SortArray:
    SortLoop:
        If RawData(CounterA+1) < RawData(CounterA) then
            DataA=RawData(CounterA)
            RawData(CounterA)=RawData(CounterA+1)
            RawData(CounterA+1+0)=DataA
            If CounterA > 0 then CounterA=CounterA-2
        CounterA=CounterA+1
        If CounterA < 5 then goto SortLoop
    And it works (basically, the code throws away all but the middle two samples of six & averages those two - ideal if your input data is all over the place.,...eg comparator counts etc!)...
    before....
    300
    100
    200
    600
    400
    500
    after....
    100
    200
    300
    400
    500
    600
    therefore, middle two samples are 300 + 400
    averaged middle two samples = 350
    Or a more real world example (eg a comparator interrupt count jittering in or around the 200 count level but with one spurious/erroneous count of 400 in the 'sample of six' to get rid of)...
    before....
    199
    400
    200
    200
    199
    200
    after....
    199
    199
    200
    200
    200
    400
    therefore, middle two samples are 200 + 200
    averaged middle two samples = 200
    Not entirely sure what the problem was (I changed a few things at once & didn't retrace my steps!)
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 07:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 17:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 19:17
