Averaging AtoD samples
Results 1 to 40 of 40
Threaded View
  1. #8
    Mar 2009
    The first 10 would be tossed but the second 10 would not because now the pairs are 10,10,11...
    Aah...ok, gotcha.
    Actually my example 'data series' wasn't a good one, as the data values would actually be in the hundreds (vs units which I used), which allows percentages to be used.
    So, assuming a series of data coming into a variable called 'sample'...
    ' compare a pair called value & value2 from the incoming 'sample'
    value = sample     '
    upper_window = value2+(value2*4/100) 'create a window 4% above previous sample
    lower_window = value2-(value2*4/100)  'create a value 4% below previous sample
    if (value>= lower_window) AND (value <= upper_window) then incoming 'sample is within 'allowable error window'?
    gosub average 'goto averaging routine
    value2 = value1
    etc
    would something like the above work?#
    Edit: Just seen your post/link scalerobotics - off to have reader's digestion! (& yes, I did a search but I guess my keywords weren't erhm key)
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 07:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 17:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 19:17
