Not sure about the writing problem.
The errors.
Open SDFS and about 70 lines down it has the errors listed. #2 is "card not present", #63 I do not see.
But, to get around the problem I have this in my "SDINIT" routine.
Here is a snippet from my code template.Code:IF (FAT_error = 6) THEN SD_MAIN
Code:'############################################### SD_MAIN: TOGGLE PORTD.7 GOSUB SDINIT GOSUB SDFILENAME GOSUB SDOPEN_W GOSUB SD_WRITE GOSUB SDCLOSE RETURN '############################################################## SDINIT: ' FSInit initializes the card and reads all the preliminary information from it Gosub FSInit Serout2 PORTC.6, 16572, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a] IF (FAT_error = 6) THEN SD_MAIN If (FAT_error != 0) Then Stop ' Display card directory Gosub FINDfirst ' Find first file on card While (FAT_error = 0) Serout2 PORTC.6,16572, [Str FAT_FileName\11, $d, $a] Gosub FINDnext ' Find next file on card Wend RETURN '################################################################
. Now, I think it's time for me to upgrade to PBP 2.60. My main concern
with the upgrade is that I think (I hope I'm wrong) that half of my programs won't work with the new PBP version. I know from reading other threads that I will need to modify the USB part of my programs.
