MicroSD Cards and SDFS
Results 1 to 34 of 34
    I do not have a good answer at the moment. I mostly use SD card for logging and yes the FAT file system can be a bit slow.
    How often is the display updated in your app?
    Miami, Florida USA
    ........ and yes the FAT file system can be a bit slow.
    So, is the FAT32 (SDFSHC32) much faster than FAT (SDFS3)? I didn't go for the FAT32 because it takes a lot of space in the chip.
    The display changes whenever a new screen is selected and hopefully the transition should be smooth. What do you think would be the best way to read the data from the card the way I need it?
    Can not say exactly but FAT32 should be a little slower, larger sectors to read I guess.
    Can you have the data on the card in CSV format instead of line by line? Be a little less reading.
    Might post your code, maybe someone will see something?
    Miami, Florida USA
    Good guess! I did some research in google and FAT32 is slower than FAT. I think that I found a solution to the problem I'm having, but I have to test it before I post it here.
    My code is just the SDFS code, the EasyHID code, and the code to drive the TFT display all mixed together. I'm just testing everything together and so far my program is working fine.
    Miami, Florida USA
    mackrackit,
    I probably found a way to speed up the process of writing to the TFT display. If you write bytes to the SD card with values from 0 to 255, which is what I need
    ' Write to file
    FOR I = 0 TO 255
        FAT_src[0] = I
        FAT_count = 1
        Gosub FSfwrite
        Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
        If (FAT_error != 0) Then Stop
    NEXT I
    The program will sucessfully write 256 bytes to the txt file (a bunch of weird characters ). Now, when you try to read them back, it will always give you wrong values between the byte 210th and the byte 250th. However, by using only 7 bits in every byte (from 0 to 127) I can make my display work pretty fast. Have you seen this happen to you? Any comments?
    Now, for some strange reason my SD card is only working the first time after I reprogram the 18F4550 chip. The second time that I restart the chip I get the following errors for the FSinit
    FAT_error = 6
    SDC_status = 2
    SDC_response = 63
    I know what the FAT_error = 6 is (Init error), but the others I'm not sure what they are. Have you encounter these kind of errors before? Remember, it always works right after I reprogram the MCU. Any ideas?
    Thank you for all your help
    Not sure about the writing problem.
    The errors.
    Open SDFS and about 70 lines down it has the errors listed. #2 is "card not present", #63 I do not see.
    But, to get around the problem I have this in my "SDINIT" routine.
    IF (FAT_error = 6) THEN SD_MAIN
    Here is a snippet from my code template.
     SD_MAIN:
        TOGGLE PORTD.7
        GOSUB SDINIT
        GOSUB SDFILENAME
        GOSUB SDOPEN_W
        GOSUB SD_WRITE
        GOSUB SDCLOSE
     RETURN      '##############################################################
    SDINIT:
    ' FSInit initializes the card and reads all the preliminary information from it
    Gosub FSInit
    Serout2 PORTC.6, 16572, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
        ' Display card directory
        Gosub FINDfirst        ' Find first file on card
        While (FAT_error = 0)
            Serout2 PORTC.6,16572, [Str FAT_FileName\11, $d, $a]
            Gosub FINDnext    ' Find next file on card
        Wend
    Miami, Florida USA
    mackrackit,
    Thank you for your help. I will try that as soon as I get out of work. I will keep you posted.
    Miami, Florida USA
     SD_MAIN:
        TOGGLE PORTD.7
        GOSUB SDINIT
        GOSUB SDFILENAME
        GOSUB SDOPEN_W
        GOSUB SD_WRITE
        GOSUB SDCLOSE
    SDINIT:
    Gosub FSInit
        Wend
    mackrackit,
    Thank you. It worked. I wrote a loop
    WHILE FAT_error = 6
         GOSUB FSInit
    WEND
