Switch in PIC BASIC HELP!!!!
Results 1 to 35 of 35
    May 2010
    Thanks,for your help,
    but not working!
    I need this program, because I try make program for some light show,when I press button,to change program,and still working,in some of this my program!
    Are we seeing the whole code?
    Have you turned any ANALOG off?
    And if that does not work tell what is happening.
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by dragan77 View Post
    but not working!
    Post your complete code (all lines) and you might get a better response.
    The code I posted works the way you want to.. but requires two buttons... is that such a problem ?
    May 2010
    First,THANKS ALL FOR HELP!!!
    THIS IS CODE i WILL TRY TO MODIFIED,
    ButtonPressCounter var byte
    SWITCHLOOP:
    IF PORTA.2 = 0 THEN
    IF ButtonPressCounter = 3 THEN ButtonPressCounter = 0
    ButtonPressCounter = ButtonPressCounter + 1
    IF ButtonPressCounter = 1 THEN GOSUB Program1
    IF ButtonPressCounter = 2 THEN GOSUB Program2
    IF ButtonPressCounter = 3 THEN GOSUB Program3
    GOTO SWITCHLOOP:
    Program1:
    high portb.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    Program2:
    high portb.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    Program3:
    high portb.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    This code work good,but,I need just when I press my button,then,
    still working on some on this may program,
    program1,program2,program3!!!
    I do not how I make some changes,that will be working!
    Sep 2009
    Hello.
    Can you please give us a bit more detailed description of what are you trying to achieve. In the meantime you could try this:
    led_tm	var word
    led	var byte
    indx	var byte
    dbc	var byte
    led_f	var bit
    symbol 	key=porta.2
    poke $1F,7	'turn off comparator
    poke $9F,0	'turn off voltage reference
    porta=0: portb=0
    trisa=%00010100
    trisb=%00000000
    led_f=0: led_tm=0: indx=3
    MAIN:
    pause 1
    if key=0 then dbc=dbc+1		'use this if porta.2 is pulled high
    'if key=1 then dbc=dbc+1	'use this if porta.2 is pulled low
    if dbc=70 then gosub SWITCH_LED
    if dbc>72 then dbc=72
    if key=1 then dbc=0		'use this if porta.2 is pulled high
    'if key=0 then dbc=0		'use this if porta.2 is pulled low
    led_tm=led_tm+led_f
    if led_tm=500 then
    	toggle led
    	led_tm=0
    goto MAIN
    SWITCH_LED:
    indx=indx+1
    if indx>2 then indx=0
    lookup indx,[1,2,3],led
    toggle led
    led_f=1
    May 2010
    Thanks so much,Grinder,for your help!!!
    I try your code,and working good,just what I wont to do in my project,when I press button in PORTA.2, to change program,and still in same program,
    and your code do it that!
    But,can,you ex plane me,what I must do, which peace,of your code,I must change,
    if I like to change, which port I like to be low,of high,I mean because I like to make some ,to combinations of led,to high,or low,to I do it myself!
    malc-c's Avatar
    malc-c Guest
    To be fair, paste up your complete code as it is and then people can see what you want to do and hopefully post a corrected version for you. To ask for help and only post up cryptic bits of code makes it hard to provide the support you are seeking
    May 2010
    Ok,I try modification this code:
    switch var byte
    if portb.2 = 1 then
    switch = switch +1
    If switch = 1 then goto program1
    If switch = 2 then goto program2
    If switch = 3 then goto program3
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    GOTO program3
    and what I need,
    when I press button,JUST ONE TIME,TO, PORTB.2,
    TO GO TO PROGRAM 1,
    AND STILL WORKING IN THE PROGRAM 1.
    when I press button,NEXT TIME,TO, PORTB.2,
    TO GO TO PROGRAM 2,
    AND STILL WORKING IN THE PROGRAM 2.
    TO GO TO PROGRAM 3,
    AND STILL WORKING IN THE PROGRAM 3,.......
    THAT I NEED!!!
