Switch in PIC BASIC HELP!!!!
Results 1 to 35 of 35
Threaded View
  1. #11
    malc-c's Avatar
    malc-c Guest
    Default with two buttons
    Hope this helps.
    This code will need changing as it's in PBP, but the logic should still work with PB. I've used this to select options in a menu by pressing one button and then another to jump to the option selected, so in theory it could be used to select which program you run
    LCDOUT $FE,2,"Main Menu"
    lcdout $FE, $C0, "Select Option"
    if Option = 1 THEN lcdout $FE, $D4, "Set Time and Date  "
    if option = 2 then lcdout $FE, $D4, "Set Night Period   "
    if option = 3 then lcdout $FE, $D4, "Set Normal Temps   "
    if option = 4 then lcdout $FE, $D4, "Run                "
    IF !H_butt THEN Option = option + 1 ; if button is low
    pause 150
    if option >4 then option = 0
    If option = 1 Then ; if option =1 and S_but is taken low then reset LCD and gosub debounce followed by jump to option selected
    If S_butt = 0 Then
    LCDOUT $FE,1
    Gosub SetButtonRelease
    goto  setup
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto nitetime
    If option = 3 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto GetSetpoint
    If option = 4 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    Goto mainmenu
    The reason I use two buttons (one to select the option and one to confirm it) is that if you don't I found it hard to get passed the first option. For example, if you had
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    GOTO program3
    switch =0
    if portB.0 = 0 then switch = switch +1
    If switch = 1 then goto program 1
    If switch = 2 then goto program 2
    If switch = 3 then goto program 3
    if switch >3 then switch=0
    then as soon as you press your switch and the variable switch=1 it would jump to program 1 and never reach program 2 or 3.
    Hope this helps, and sorry it's not converted into PB that you can use directly, but hopefully that won't be too hard to cchange
