Switch in PIC BASIC HELP!!!!
Results 1 to 35 of 35
    May 2010
    Default Switch in PIC BASIC HELP!!!!
    Hay,all!!!!
    Can somebody help me in Picbasic programing!
    I need some code to switch with one button,to change to next program!
    Example:
    program1:
    some doing
    goto program 1
    program2:
    some doing
    goto program2
    program3:
    some doing
    goto program3 .......
    and can some help me how I write some code for the button,when I press button ONE TIME,to I change to
    program1
    program2
    program3......
    to change program,when I PRESS MY BUTTON ONE TIME,TO AUTOMATIC GO TO CHANGE PROGRAM!
    If some body can help me,how i do that un PIC BASIC!
    There are several possible ways depending on what it is your doing on the various "programs", here's one aproach.
    Set up one of the PIC's timers, say TMR0 as a counter, have your button, with some debounce circuitry connected to the external input of the timer.
    Then you have a main loop which checks the value of the TMR0 register and jumps to appropriate sub program, when the value of TMR0 is lager than the "last" sub-program you reset the TMR0 register to 0.
    Something like, for a 16F628:
    TRISA.4 = 1
    OPTION.5 = 1   		'Set TMR0 as Counter, input is on RA4.
    OPTION.4 = 0   		'Count on rising edge.
    TMR0 = 0       		'Reset TMR0 register
    Select Case TMR0
      Case 0
        Goto ProgramZero
      Case 1
        Goto ProgramOne
      Case 2
        Goto ProgramThree
      Case Else
        TMR0 = 0
    Goto Main
    ProgramZero:
      'Do This
     Goto Main
    ProgramOne:
       'Do That
     Goto Main
    ProgramThree:
      'Do Something else
     Goto Main
    Another aproach is to wire the switch to an external interrupt pin and use the interrupt request flag to increment a software pointer quite similar to the TMR0 counter above. On the 16F628 PortB.0 is the interrupt pin
    TRISB.0 = 1    'PortB.0 as input.
    OPTION.6 = 1   'Set interrupt flag on rising edge of PortB.0
    If INTCON.1 = 1 then
       INTCON.1 = 0   		'Reset flag
       myPointer = myPointer + 1
       If myPointer = 3 then myPointer = 0  'Wrap around
    Select Case myPointer
    and then like in the first example...
    If you want "instant" switching of programs then you'll need to actually enbale the interrupt as well, not only check the flag, and then do the "program switching" in the interrupt handler.
    Well, there's a couple of ideas for you.
    Hello again,
    I'm sorry but I missed the fact that you wasn't using PBP. In that case it get's a little more complicated, the Select Case (which I don't think PBC supports) can be substitutes with some If Then lines. But the reading and writing of the various register will have to be done with PEEK and POKE and you need to use the datasheet for your particular PIC to figure out which physical adresses the various registers are at.
    May 2010
    Thanks, a lot Henrik,
    but when I try compile your program,I have syntax error!
    I am new in programing,can you write me some new code,
    about PEEK OR POKE,how you write me last time,
    because I do no,t now how I do that!
    Thanks a lot again!!!
    May 2010
    One question more!
    What you mean line
    OPTION.5=1
    AND
    OPTION.4=0
    WHAT I MUST WRITE IN THIS 2 LINES?
    Because I have syntax error.
    Hello,
    OPTION.5 = 1 simply sets bit 5 in the option register but like I said in my previous post PBC doesn't support direct register access like that so you'll have to use POKE to write the registers and PEEK to read them. Look at the memory map of the device you're working with. You'll find at which adresses the various registers are. On the 16F628 the OPTION register is at location 80h for example.
    Look in the PBC manual on how to use POKE and PEEK.
    Why did I want to set bit5 in the option register? That's because it is the bit that select if TMR0 is a timer or counter and I found that information in the section of datasheet dedicated to TMR0.
    May 2010
    Hello,
    I don.t understood how I do that.
    I use device PIC16f628,
    I just need when I PUSH BUTTON ONE TIME,
    then working program 1,
    when I push button next time,
    go to next program 2,
    go to next program 3,......
    Can you write me code in PIC BASIC code for that,
    if you cant,
    thanks anyway!!!
    I have not used Pic Basic so I can not help much but here is a "not very good idea" you might play with while you are working out the register reading Henrik is pointing you to.
    Setup a BUT_CHECK routine with a RETURN at the end of it.
    In each of the program loops have a GOSUB BUT_CHECK.
    The BUT_CHECK routine will check if the button IS pressed and if it is increment a variable by one.
    When the code returns to the program running the next line will have something like.
    IF BUT_VAR = 2 GOTO PROG 2
    Lots of problems with doing it this way but if things are not critical....
    When you figure out the registers with Pic Basic you should see how bad of an idea this is.
    Default Program selection on button press
    Try this idea, it works with PBP in a PIC18F4620 and should work with any PIC that has EEPROM.
    I set a byte variable "ProgramState" to 1 in a data statement and write this to EEPROM when the program is loaded into the PIC.
    At power up, the code reads the value stored in ProgramState, here set to 1, and jumps to the appropriate code block.
    MAIN:
    READ 0, ProgramState
    If ProgramState = 1 then RunCode1
    If ProgramState = 2 then RunCode2
    If ProgramState = 3 then RunCode3
    If ProgramState > 3 then
    write 0, 1 'reset ProgramState to first code block
    goto MAIN
    RunCode1:
    execute codeblock 1
    if ButtonDown = 1 then
    write 0, 2
    goto MAIN
    RunCode2:
    execute codeblock 2
    write 0, 3
    goto MAIN
    etc
    HTH
    BrianT
    May 2010
    Thanks,Braian,for help,
    I try your idea,but doesn't,work.
    I try explain what I need,example:
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    GOTO program3 .........
    and now I don't now how,how I make code for switch!
    I need,when I press switch,JUST ONE TIME,
    and every time when I press switch again,
    to change program1,program2,program3,......
    that is problem!
    malc-c's Avatar
    malc-c Guest
    Default with two buttons
    Hope this helps.
    This code will need changing as it's in PBP, but the logic should still work with PB. I've used this to select options in a menu by pressing one button and then another to jump to the option selected, so in theory it could be used to select which program you run
    LCDOUT $FE,2,"Main Menu"
    lcdout $FE, $C0, "Select Option"
    if Option = 1 THEN lcdout $FE, $D4, "Set Time and Date  "
    if option = 2 then lcdout $FE, $D4, "Set Night Period   "
    if option = 3 then lcdout $FE, $D4, "Set Normal Temps   "
    if option = 4 then lcdout $FE, $D4, "Run                "
    IF !H_butt THEN Option = option + 1 ; if button is low
    pause 150
    if option >4 then option = 0
    If option = 1 Then ; if option =1 and S_but is taken low then reset LCD and gosub debounce followed by jump to option selected
    If S_butt = 0 Then
    LCDOUT $FE,1
    Gosub SetButtonRelease
    goto  setup
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto nitetime
    If option = 3 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto GetSetpoint
    If option = 4 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    Goto mainmenu
    The reason I use two buttons (one to select the option and one to confirm it) is that if you don't I found it hard to get passed the first option. For example, if you had
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    GOTO program3
    switch =0
    if portB.0 = 0 then switch = switch +1
    If switch = 1 then goto program 1
    If switch = 2 then goto program 2
    If switch = 3 then goto program 3
    if switch >3 then switch=0
    then as soon as you press your switch and the variable switch=1 it would jump to program 1 and never reach program 2 or 3.
    Hope this helps, and sorry it's not converted into PB that you can use directly, but hopefully that won't be too hard to cchange
    SWITZERLAND (french speaking)
    Another way to do it
    ButtonPressCounter = 0
    SWITCH-LOOP:
    IF PORTx.x = 0 THEN     'this is where your button is connected to, obviously
       IF ButtonPressCounter = 3 THEN ButtonPressCounter = 0
       ButtonPressCounter    = ButtonPressCounter + 1
       IF ButtonPressCounter = 1 THEN GOSUB Program1:
       IF ButtonPressCounter = 2 THEN GOSUB Program2:
       IF ButtonPressCounter = 3 THEN GOSUB Program3:
    GOTO SWITCH-LOOP:
    Program1:
    ...do something
    Program2:
    ...do something
    Program3:
    ...do something
    Roger
    May 2010
    Thanks,Roger
    but can i ask you some!
    Is it finish code for compile,or some of combination,to I use!
    Can you write finish code for compile, because I am new in programing!
    Quote Originally Posted by dragan77 View Post
    Is it finish code for compile...
    Almost!
    Set the PORTx.x you are going to use for your button and program your routines and you're done.
    Roger
    May 2010
    Thanks,but when I use this code:
    SWITCH-LOOP:
    IF PORTA.2 = 0 THEN
    GOTO SWITCH-LOOP:
    Program1:
    high portb.1
    Program2:
    high portb.2
    Program3:
    high portb.3
    WHEN I TRY COMPILE IN PIC BASIC,THEN GIVE ME THIS ERRORS!
    ERROR Line 1: Syntax error.
    ERROR Line 3: Syntax error.
    ERROR Line 4: IF without a matching ENDIF.
    ERROR Line 5: Bad expression.
    ERROR Line 5: Bad expression or missing THEN.
    ERROR Line 5: IF without a matching ENDIF.
    ERROR Line 6: Syntax error.
    ERROR Line 7: Bad expression.
    ERROR Line 7: Bad expression or missing THEN.
    ERROR Line 7: IF without a matching ENDIF.
    ERROR Line 8: Bad expression.
    ERROR Line 8: Bad expression or missing THEN.
    ERROR Line 8: IF without a matching ENDIF.
    ERROR Line 9: Bad expression.
    ERROR Line 9: Bad expression or missing THEN.
    ERROR Line 11: Syntax error.
    I DO NOT NOW WHY,WHAT IS HAPPENED?
    Is that the whole code?
    Is the line
    ButtonPressCounter VAR BYTE
    in there someplace?
    May 2010
    Thanks,for help,but can you give me one more answer!
    I write this code:
    ButtonPressCounter var byte
    SWITCHLOOP:
    IF PORTA.2 = 0 THEN
    GOTO SWITCHLOOP:
    Program1:
    high portb.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    Program2:
    high portb.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    Program3:
    high portb.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    is Ok,code working,
    but how I do it,when I switch button,to change program,and stay work in this some of this program?
    Sorry, but I do not understand the question.
    May 2010
    I try ex plane,my question!
    I mean!
    I need when I press button one time,
    then in my case go to program1,
    and still working in program1!
    When I press button second time then
    go to program2,
    and still working in program2,
    When I press button 3.rd time then
    go to program3,
    and still working in program3,......
    Maybe...
    SWITCHLOOP:
    IF PORTA.2 = 0 THEN ButtonPressCounter = ButtonPressCounter + 1
    IF ButtonPressCounter = 4 THEN ButtonPressCounter = 0
    GOTO SWITCHLOOP:
    maybe not... See what happens.
    May 2010
    Thanks,for your help,
    but not working!
    I need this program, because I try make program for some light show,when I press button,to change program,and still working,in some of this my program!
    Are we seeing the whole code?
    Have you turned any ANALOG off?
    And if that does not work tell what is happening.
    malc-c's Avatar
    malc-c Guest
    but not working!
    Post your complete code (all lines) and you might get a better response.
    The code I posted works the way you want to.. but requires two buttons... is that such a problem ?
    May 2010
    First,THANKS ALL FOR HELP!!!
    THIS IS CODE i WILL TRY TO MODIFIED,
    SWITCHLOOP:
    IF PORTA.2 = 0 THEN
    GOTO SWITCHLOOP:
    Program1:
    high portb.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    Program2:
    high portb.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    Program3:
    high portb.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    This code work good,but,I need just when I press my button,then,
    still working on some on this may program,
    program1,program2,program3!!!
    I do not how I make some changes,that will be working!
    Sep 2009
    Hello.
    Can you please give us a bit more detailed description of what are you trying to achieve. In the meantime you could try this:
    led_tm	var word
    led	var byte
    indx	var byte
    dbc	var byte
    led_f	var bit
    symbol 	key=porta.2
    poke $1F,7	'turn off comparator
    poke $9F,0	'turn off voltage reference
    porta=0: portb=0
    trisa=%00010100
    trisb=%00000000
    led_f=0: led_tm=0: indx=3
    MAIN:
    pause 1
    if key=0 then dbc=dbc+1		'use this if porta.2 is pulled high
    'if key=1 then dbc=dbc+1	'use this if porta.2 is pulled low
    if dbc=70 then gosub SWITCH_LED
    if dbc>72 then dbc=72
    if key=1 then dbc=0		'use this if porta.2 is pulled high
    'if key=0 then dbc=0		'use this if porta.2 is pulled low
    led_tm=led_tm+led_f
    if led_tm=500 then
    	toggle led
    	led_tm=0
    goto MAIN
    SWITCH_LED:
    indx=indx+1
    if indx>2 then indx=0
    lookup indx,[1,2,3],led
    toggle led
    led_f=1
    May 2010
    Thanks so much,Grinder,for your help!!!
    I try your code,and working good,just what I wont to do in my project,when I press button in PORTA.2, to change program,and still in same program,
    and your code do it that!
    But,can,you ex plane me,what I must do, which peace,of your code,I must change,
    if I like to change, which port I like to be low,of high,I mean because I like to make some ,to combinations of led,to high,or low,to I do it myself!
    malc-c's Avatar
    malc-c Guest
    To be fair, paste up your complete code as it is and then people can see what you want to do and hopefully post a corrected version for you. To ask for help and only post up cryptic bits of code makes it hard to provide the support you are seeking
    May 2010
    Ok,I try modification this code:
    switch var byte
    if portb.2 = 1 then
    switch = switch +1
    If switch = 1 then goto program1
    If switch = 2 then goto program2
    If switch = 3 then goto program3
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    GOTO program3
    and what I need,
    when I press button,JUST ONE TIME,TO, PORTB.2,
    TO GO TO PROGRAM 1,
    AND STILL WORKING IN THE PROGRAM 1.
    when I press button,NEXT TIME,TO, PORTB.2,
    TO GO TO PROGRAM 2,
    AND STILL WORKING IN THE PROGRAM 2.
    TO GO TO PROGRAM 3,
    AND STILL WORKING IN THE PROGRAM 3,.......
    THAT I NEED!!!
    malc-c's Avatar
    malc-c Guest
    Long way, but possibly a fix is to incorporate the test for switch in each program
    if portb.2 = 1 then
    switch = switch +1
    program1:
    HIGH PORTB.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    if portb.2 = 1 then
    switch = switch +1
    GOTO program1
    program2:
    HIGH PORTB.2
    PAUSE 500
    LOW PORTB.2
    PAUSE 500
    if portb.2 = 1 then
    switch = switch +1
    GOTO program2
    program3:
    HIGH PORTB.3
    PAUSE 500
    LOW PORTB.3
    PAUSE 500
    if portb.2 = 1 then
    switch = switch +1
    GOTO program3
    crude code, but may work (I've not tested as I'm at work)
    malc-c's Avatar
    malc-c Guest
    THAT I NEED!!!
    Oh and no need to shout !
    This is what I understand you may be looking for (not tested yet).
    MAIN:
       IF PORTA.2 = 0 THEN
          PAUSE 300 'debounce
          GOTO Program1:
       GOTO MAIN:
    Program1:
       IF PORTA.2 = 0 THEN
          PAUSE 300
          GOTO Program2:
       HIGH PORTB.1
       PAUSE 500
       LOW PORTB.1
       PAUSE 500
       GOTO Program1:
    Program2:
       IF PORTA.2 = 0 THEN
          PAUSE 300
          GOTO Program3:
       HIGH PORTB.2
       PAUSE 500
       LOW PORTB.2
       PAUSE 500
       GOTO Program2:
    Program3:
       IF PORTA.2 = 0 THEN
          PAUSE 300
          GOTO Program1:
       HIGH PORTB.3
       PAUSE 500
       LOW PORTB.3
       PAUSE 500
       GOTO Program3:
    ...Can you write finish code for compile, because I am new in programing!
    Thanks,for your help,but not working!
    But,can,you ex plane me,what I must do, which peace,of your code,I must change...
    My question to you dragan77: is this thread really 30 replies worth? What are your personal inputs and efforts?
    It looks a bit frustrating to me....
    Roger
    Sep 2009
    Hello.
    Please forgive me, but I'm still not sure what are you trying to do. What puzzles me most is PAUSE 500 because when a program is executing PAUSE it can't do anything else until the specified period expire (unless abrupted by interrupt). In your case, whenever the program hits PAUSE 500 it is just sitting there for the half of a second.
    In my example the program is looping in MAIN waiting a key to be pressed (with some sort of debounce routine) and counting ~500ms ON/OFF time for the appropriate LED (it counts nothing until the key is pressed for the first time). After keypress it jumps to SWITCH_LED subroutine where it adjusts index (indx variable) to grab a value from the LOOKUP table in order to toggle an appropriate LED (that way I'm addresing a port by its number instead by its name), and then returns in main loop.
    To change ports with attached LEDs you need to change values in LOOKUP table. You can use numbers 0-15 instead of port names, where 0 is portb.0, and 15 would be porta.7. However on 16F628 you can go as far as 12 (porta.4) or 13 (porta.5), depending whether you use external or internal oscillator. It's not same for all PICs. For example on 16F877 you can use full range of 0-15 because it spreads over portb and portc.
    Sep 2009
    Hello.
    First, I want to apologize for taking liberty to correct other people's code. In post no. 31 mr. Roger (flotulopex) accidentaly made a mistake:
    MAIN:
       IF PORTA.2 = 0 THEN
          <font color="red">PAUSE 300 'debounce</font>
          GOTO Program1<font color="red">:</font>
       GOTO MAIN<font color="red">:</font>
    Those colons marked red are surplus and that PAUSE 300 doesn't do any debounce here. It is simply executed immediately after the porta.2 goes low. The most simple way to verify that is to change pause to some larger value, e.g. 1000 (1 sec.) and apply very short (less than 1 sec.) push on button. What will happen is that LED will toggle its state after the pause no matter how shortly you kept the button pressed.
    If it was written like this:
    IF PORTA.2 = 0 THEN
    	PAUSE 300
    	IF PORTA.2 = 0 THEN Program1
    On button-press the program would make a 300ms debounce-pause and then check again if button is still pressed and perceived if it was real button-press or just random noise.
    Default mistake or no mistake?
    Hi grinder,
    Thanks for your corrections but there is sometimes an explanation behind "strange looking" code.
    If you didn't tested this yet, do so and you will discover that the "debounce" will prevent the code to jump from the MAIN loop directly to the Program2 label; just try...and see by yourself
    You're right, the colons are not necessary but this is just because I copy/paste the code instead of retyping it. BTW, this will make absolutely no change to the compiled code.
    Dragan77 seems to be looking for a simple program made of simple commands for simple functionality; I'm not sure his application needs "complexity" up to using LOOKUP and so on.
    Roger
    Sep 2009
    Hello.
    Mr. Roger (flotulopex), I apologize once more.
    No need to test it, you're absolutely right about that. I made a mistake taking piece of your code out of the content. My intention was to explain that debouncing should represent a protection against random noise, beside inadvertently key presses. I'm really sorry, I didn't eplained that adequately.
    You're right, the colons are not necessary but this is just because I copy/paste the code instead of retyping it...
    That's why I said that you accidentaly made a mistake.
    I beleive you're right about that as well. I put my example more as a probe to see if that's what mr. Dragan77 wants to achieve.
