Hello.
First, I want to apologize for taking liberty to correct other people's code. In post no. 31 mr. Roger (flotulopex) accidentaly made a mistake:
Those colons marked red are surplus and that PAUSE 300 doesn't do any debounce here. It is simply executed immediately after the porta.2 goes low. The most simple way to verify that is to change pause to some larger value, e.g. 1000 (1 sec.) and apply very short (less than 1 sec.) push on button. What will happen is that LED will toggle its state after the pause no matter how shortly you kept the button pressed.Code:MAIN: IF PORTA.2 = 0 THEN <font color="red">PAUSE 300 'debounce</font> GOTO Program1<font color="red">:</font> ENDIF GOTO MAIN<font color="red">:</font> ...
If it was written like this:
On button-press the program would make a 300ms debounce-pause and then check again if button is still pressed and perceived if it was real button-press or just random noise.Code:IF PORTA.2 = 0 THEN PAUSE 300 IF PORTA.2 = 0 THEN Program1 ENDIF
