I2C Slave with a PIC
Results 1 to 40 of 130
    Nov 2008
    Hello Al,
    another question:
    What are the three definitions:
    1. DEFINE I2C_SLOW 1
    2. DEFINE I2C_HOLD 1
    3. DEFINE I2C_SCLOUT 1
    do?
    1. => Used with LO > 8MHz and 100kHz devices
    2. => Time Delay during acknowledge?
    3. => Open Collector / Bipolar Clock on SCL? Dont Understand this!
    So: I use PCF8575C and MAX3611 (both 400kHz devices) but both only work
    correct when DEFINE I2C_HOLD 1 and DEFINE I2C_SCLOUT 1 is done.
    Can you help?
    Ralf
    Quote Originally Posted by ralfmayr View Post
    Hello Al,
    another question:
    do?
    Can you help?
    Ralf
    Hi Ralf,
    I can answer part of #3:
    Open collector means the PIC has 2 states LOW where it takes the pin to ground and an open state where the pin is high impedance, so to get a high state it must have a pull up resistor to supply the power. I do not know what bipolar clock means, have not read up on this yet.
    May 2008
    Italy
    Yes.
    Not Exactly, data transfer can be paused by the receiving device by holding the clock line low, so the receiving device can control the data flow. To enable this function you need the DEFINE I2C_HOLD 1 declared.
    Joe already answer to this point with a clear explanation. Let me add that bipolar is a device capable to pullup the lines by itself without the need of external pullup resistors
    It is usefull to use DEFINE I2C_HOLD 1 as default since it will keep synchronized different devices connected on the I2C bus all with different internal clock.
    I don't know much about PCF8575C and MAX3611 but very likely they are bipolar devices.
    Al.
    Nov 2008
    Thank you both for the answers.
    Now i understand.
    So it seems always to be best to work with declaration 2 & 3 with
    400 khz devices. This is what i found out yesterday.
    Have nice eastern!
    Ralf
    Perth, Australia
    Hi all. I need to synchronise an array from one PIC to another (one way only), so I have been working to make a simplified version of the code seen in this thread with just the bare essentials to send the array from slave to master.
    It mostly works, but there is one little bug. I am sending the array over and over again - the test array is 6 bytes and I have assigned test values of 1 2 3 4 5 and 6.
    On the 1st i2cread the master receives 123456. On the 2nd i2cread it gets 234561, and the third 345612. It seems that every time I do an i2cread, the following byte goes missing. The first time I get 123456, the next 1 goes into oblivion and therefore the next packet is 234561.
    I know I can get around this by sending a dummy byte after the array, knowing that it will be lost, but I'd like to know why this is happening if anyone has any ideas?
    Master PIC (18F2620, 40Mhz HSPLL):
    DEFINE OSC 40
    DEFINE I2C_HOLD 1
    DEFINE LCD_DREG         PORTB
    DEFINE LCD_DBIT         0
    DEFINE LCD_RSREG        PORTB
    DEFINE LCD_RSBIT        4
    DEFINE LCD_EREG         PORTB
    DEFINE LCD_EBIT         5
    DEFINE LCD_BITS         4
    DEFINE LCD_LINES        2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS       50
    PAUSE 100
    LCDOUT $FE,1,$FE,2
    ADCON1=%00001111
    CMCON=%00000111
    scl             VAR PORTC.3
    sda             VAR PORTC.4
    i2c_address     VAR BYTE
    i2c_data        VAR BYTE[6]
    i2c_address=$0A
    I2CREAD sda,scl,i2c_address,[STR i2c_data\6]
    LCDOUT $FE,$80,DEC i2c_data[0]
    LCDOUT " ",    DEC i2c_data[1]
    LCDOUT " ",    DEC i2c_data[2]
    LCDOUT " ",    DEC i2c_data[3]
    LCDOUT " ",    DEC i2c_data[4]
    LCDOUT " ",    DEC i2c_data[5]
    PAUSE 1000
    GOTO main
    Slave PIC (18F2620, 40Mhz HSPLL):
    DEFINE OSC 40
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    ADCON1=%00001111
    CMCON=%00000111
    i2c_buffer_full     VAR SSPSTAT.0
    i2c_read            VAR SSPSTAT.2
    i2c_release_scl     VAR SSPCON1.4
    i2c_data_index      VAR BYTE
    dummy               VAR BYTE
    SSPADD=$0A          ' I2C Address: $0A
    SSPCON1=$36
    SSPCON2.0=1
    i2c_data[0]=1
    i2c_data[1]=2
    i2c_data[2]=3
    i2c_data[3]=4
    i2c_data[4]=5
    i2c_data[5]=6
    i2c_data_index=0
    INT_LIST  macro
            INT_Handler SSP_INT, _i2c_int_handler, PBP, yes
        INT_CREATE
        INT_ENABLE SSP_INT
    endasm
    ' main program goes here
    i2c_int_handler:
    IF i2c_read then
        dummy=SSPBUF
        IF i2c_buffer_full=0 THEN
            SSPBUF=i2c_data[i2c_data_index]
            i2c_data_index=i2c_data_index+1
            IF i2c_data_index=6 THEN i2c_data_index=0
    i2c_release_scl=1
    @ INT_RETURN
    Hey Kamikaze,
    I didn't see a problem from just looking at the code, so I ran it in the simulator.
    And I don't see a problem there either.
    On the master I get " 1 2 3 4 5 6".
    It does not change.
    I only added a toggle in the Master's main loop to verify it was looping.
    And a toggle in the Slave's handler, to verify the transfers.
    Is there something you stripped out before posting that could have caused it?
    Perth, Australia
    Thanks for looking DT. I'm currently running the above code "as is" on 2 breadboards side by side.
    Still losing a byte every time I do an i2cread.
    I tried reading one byte at a time instead of six, and I get: 1, 3, 5, 1, 3, 5. So no matter how many bytes I receive at once, it always skips the byte immediately proceeding those bytes.
    *edit* My circuit is identical to yours there DT except for 10mhz crystals + caps, and I only have an LCD on the master PIC.
    In case its relevant, these are my configs:
            __CONFIG    _CONFIG1H, _OSC_HSPLL_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    Hey Kamikaze,
    It does not change.
    Attachment 4704
    Last edited by Kamikaze47; - 16th August 2010 at 14:52. Reason: added more information
  1. Problem with PICto PIC I2C MASTER-SLAVE
    By juanen19 in forum mel PIC BASIC Pro
    Last Post: - 11th June 2013, 03:58
  2. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 14:23
  3. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 04:21
  4. Pic as an i2c slave
    By Robert Soubie in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 22:11
  5. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 20:26
