Hi Jellis,
I finally got a chance to look at your program. You have the pins of PortB setup for the LCD and you are also using PortB4. & 5 for the RTC alarms and PortB.0 and 1 for the I2C connections. You need to change them and set the RTC connections on a different Port.
BobK
