example code for DS1337
Results 1 to 26 of 26
    Mentor, Ohio
    Smile
    Hi Jellis,
    I only have a few minutes before I need to go to work but I use the DS1337 quite a bit and this is all I use to set the time information and to display it. Nothing else and it works great. I will check back tonight when I get home.
    SetTimeAndDate:
        yr=0:date =0:mon =0:day=0:hr=0:mins=0:sec=0     'Clear RTC variables
        A1sec=0:A1MINs=0:A1hr=0:A1day=0
        A2MINS=0:A2hr=0:A2day=0
        yr=$08                  'This section sets the RTC Variables
        mon=$06
        date=$02
        day=$01
        hr=$19
        mins=$20
        sec=$30
        A1hr=$10
        A1MINS=$00
        A1SEC=$00
        A1day=%10000000
        A2hr=$22
        A2MINS=$00
        A2day=%10000000
        Pause 10
        wRITE 5,1       'Write TO eeprom DST flag value (0 = EST  1 = DST)
            pause 20
        I2CWrite SDA, SCL, RTC, SecReg,[sec,mins,hr,day,date,mon,yr] '**Set the main Time
            Pause 20
        I2CWrite SDA, SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day] '**Set Alarm1 Time
            Pause 20
        I2CWrite SDA, SCL, RTC, Alm2min,[A2MINs,A2hr,A2day] '**Set Alarm2 Time
           Pause 20
        I2CWrite SDA, SCL, RTC, StatusReg,[%00000000]  '**Clear Status Register
            PAUSE 20
        I2CWrite SDA, SCL, RTC, ContReg,[%00000111]   '**Set Control Register for Alarm1 & Alarm2 outputs separately
            Pause 20
    '   This routine resets the status register after an alarm event
    Clear_Status:
        I2CWrite SDA, SCL, RTC, StatusReg,[%00000000]  'Reset Alarm output from DS1337
            PAUSE 20
    Display_Time:
        B2 = 0
        I2CRead SDA, SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]           '**Get current time
            pause 20
        I2Cread SDA, SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]              '**Get Alarm1 Time
            Pause 20
        I2Cread SDA, SCL, RTC, Alm2min,[A2MINs,A2hr,A2day]                    '**Get Alarm2 Time
            serout2 LCD,Baud,[I,Clr]
            serout2 LCD,Baud,[I,Line1," ",hex2 mon,"/",hex2 date,"/",hex2 yr,"  ",HEX2 hr,":",HEX2 MINs,":",Hex2 sec]
            Serout2 LCD,Baud,[I,Line2,"Alarms: ",HEX2 A1hr,":",hex2 A1MINs," ",Hex2 A2hr,":",Hex2 A2MINs]
    HTH,
    BobK
    Mentor, Ohio
    Smile
    Hi Jellis,
    I finally got a chance to look at your program. You have the pins of PortB setup for the LCD and you are also using PortB4. & 5 for the RTC alarms and PortB.0 and 1 for the I2C connections. You need to change them and set the RTC connections on a different Port.
    BobK
    Mar 2009
    Colorado
    Question I2C/LCD conflict on PortB on EasyPic6
    Quote Originally Posted by BobK View Post
    Hi Jellis,
    BobK
    Yes, I am aware of that. It is because the development board I am using (EasyPic6) hardwires PortB RB0/RB1 to the LCD that the board uses, thus making a conflict with the RB0/RB1 pins that are used by my 18F4550 MCU for the I2C interface to the DS1337. That is why I am commenting out all of the LCD related code in this test version, which unfortunately makes it difficult to troubleshoot the DS1337 clock operations without being able to see the outpus on the LCD. I am therefore using my oscilloscope to check the DS1337 pins during ops as my only way to troubleshoot...awkward!
    I have another LCD on order (two weeks delivery from Bulgaria) that will permit me to connect it as an external LCD to the EasyPic6 that will resolve this pin conflict, but in mean time I am still trying to troubleshoot code and get the clock working. Any suggestions how to troubleshoot without LCD??
    One thing I am wondering....I have the DS1337 circuit with pullup resistors and capacitor installed on an Archer Universal Breadboard with wire connections to the EasyPic6 for the I2C interface and the ALarm1 input....would this be possible cause for the clock not working due to extra capacitance from wiring/breadboard hookup? I wanted to get code working before reducing everything to an integrated PCB.
    I will try your contrl suggestion. Thanks for advice!
    Mentor, Ohio
    Smile
    Hi Jellis,
    Do you have a crystal with a capacitance load of 6pf? If not, the clock won't be very accurate.
    Yea it is kind hard to see if the RTC is working without a display. I have a serial LCD that I plug into my clock boards. The clocks run without the LCD but I only plug it in when I'm checking the times and testing the clock. I built a test program into it that lets me change the alarm times to one and two minutes from the current times and at the completion of the test it restores the alarm times to their normal settings and reboots the system. I've had 80 of them in service for almost 3 years now.
    I just tried to get a picture of the board to send to you but the limits were exceded. If you send me your email address I'll send you a picture.
    BobK
    Mar 2009
    Colorado
    Unhappy Would like to receive the photo
    I am ordering one with 6pf capacitance now...the one I have been using has 27pf capacitance and I still haven't been able to get the DS1337 to run no matter what CONTROL word I send it. Even wit %00000000, which is no alarms and 32.768kHa on the SQW output, I don't see anything on the SQW output pin or an indication that the clock is running. Frustrating! Hopefully with a LCD I will make some progress in the troubleshooting.
    I am ordering a serial serial LCD (delivery in 2 weeks) to resolve the Pin conflicts in my EasyPic6 with the I2C interface (RB0/RB1) from the 18F4550 MCU. Your test program sounds very interesting. How do you initiate the MCU to run just the test program instead of the application program?...is it when you plug something into that the MCU senses like an external PC to MCU serial cable or a USB cable? I would like to consider doing something similar in our application. Would definitely like to see the photo you offer...send to my email at [email protected].
    John,
    I'm not sure which pin you've connected SQW to, but ...
          TRISA =%00000000
          TRISB =%00000000
          TRISC =%00000000
          TRISD =%00000000
    One of the first things you do is set almost all the pins to output.
    That would stop any signal from SQW.
    If you think it is a capacitor issue and you are ordering more parts you may want to look at the DS1337C. Everything is built in.
    What voltage are you running the RTC on?
    Mar 2009
    Colorado
    Talking Stupid me!
    I seem to be having a lot of senior moments lately...this being another one. I should have caught that....once I set TRISB to provide for inputs on the pins I had connected to SQW/_INTB and _INTA the alarms worked as intended, thus indicating to me that current time and alarms were being correctly set at programming time even though I couldn't see that they were because of lack of a LCD.
    Thanks again Darrel!
    Mar 2009
    Colorado
    Thumbs down Made changes...new code still doesn't work w/ DS1337
    Thanks, BobK. I studied your code you posted and made some changes in my code to reflect what I saw. I have listed my latest code below. Also added a DEFINE OSC 48 statement that was pointed out to me by someone else as needed since I am using 48 MHz CPU clock derived from the 96 MHz clock for a USB interface I will also be adding to this code at later time.
    I also notice an anomally in my breadboard setup of the DS1337 circuit when I connect my oscilloscope to the SQW/INTB output:
    1) When power is applied to the DS1337 circuit but the code is erased from my controlling 18F4550 MCU, I see a 32.7787kHz clock signal on my oscilloscope at the SQW output of the DS1337.
    2) When I then program the 18F4550 the clock signal on SQW output disappears (flat line at 0 volts).
    This appears to be opposite to what should be happening. The clock should appear at SQW when the MCU is programmed, time has been set and DS1337 is clocking....this isn't happening.
    I also checked the INTA output to see if the Alarm1 was happening 30 seconds after programming and setting the DS1337 time, and it isn't happening either.
    Any ideas what may be causing all this?
    Include "Modedefs.Bas"
    INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
    DEFINE OSC 48
    ;--- if you un-comment these, you must comment the ones in the .inc file--
    ASM ; 18F2550/4550, 8mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    '**--SETUP FOR USING 2x16 LCD THAT IS INSTALLED IN EASYPIC6----------
        '( commented out during testing of DS1337 operations)
      ' LCD DEFINES FOR USE WIH 2x16 LCD..commented out during testing
      ' DEFINE LCD Control Constants **
        'I       CON 254           ' Control Byte
        'Clr     CON 1             ' Clear the display
        'Line1   CON 128           ' Point to beginning of line 1
        'Line2   CON 192           ' Point to beginning of line 2
    '**-------------SETUP FOR USING DS1337 Real Time Clock------------------
    ' Setup Hardware for uart
        DEFINE HSER_BAUD 115200
        DEFINE HSER_RCSTA 90h
        DEFINE HSER_TXSTA 24h
        DEFINE HSER_CLROERR 1
    ' Aliased Variables for CLock
        Alarm1      VAR PORTB.4     ' Output of Alarm1 signal
        Alarm2      VAR PORTB.5     ' Output of Alarm2 signal
        DS_SCL      VAR PORTB.1     ' I2C clock pin
        DS_SDA      VAR PORTB.0     ' I2C data pin
        RTC         CON %11010000   ' RTC device write address(byte addressing)
           'contrl     CON %00011001    ' Sets RS1 & RS2,
                                    ' clears INTCN to enable Alarm1 & 3.2768kHz
                                    ' outputs separately.
    ' -------------- RTC Address definitions
        SecReg      CON $00   ' seconds address (00 - 59)
                              ' MSB of SecReg must be set to a 0 to enable RTC
        MinReg      CON $01   ' minutes address (00 - 59)
        HourReg     CON $02   ' hours address (01 - 12) or (00 - 23)
        DayReg      CON $03   ' day address (1 - 7)
        DateReg     CON $04   ' date address (01 - 28/29, 30, 31)
        MonthReg    CON $05   ' month address (01 - 12)
        YearReg     CON $06   ' year address (00 - 99)
    'Alarm 1 Address definitions
        Alm1sec     CON $07   ' Alarm 1 seconds address (00 - 59)
        Alm1min     CON $08   ' Alarm 1 minutes address (00 - 59)
        Alm1hr      CON $09   ' Alarm 1 hours address (01 - 12) or (00 - 23)
        Alm1Day     CON $0A   ' Alarm 1 day address (1 - 7)
    'Alarm 2 Address definitions
        Alm2min     CON $0B   ' Alarm 2 minutes address (00 - 59)
        Alm2hr      CON $0C   ' Alarm 2 hours address (01 - 12) or (00 - 23)
        Alm2Day     CON $0D   ' Alarm 2 day address (1 - 7)
    ' Alias of Clock register addresses
       ContReg     CON $0E         ' CONTROL register address
       StatusReg   CON $0F         ' STATUS register address
    ' Clock Variables
        sec         VAR BYTE  ' seconds
        MINs        VAR BYTE  ' minutes
        hr          VAR BYTE  ' hours
        day         VAR BYTE  ' day
        date        VAR BYTE  ' date
        mon         VAR BYTE  ' month
        yr          VAR BYTE  ' year
    'ALARM1 VARIABLES
        A1sec       VAR BYTE  ' seconds
        A1MINs      VAR BYTE  ' minutes
        A1hr        VAR BYTE  ' hours
        A1day       VAR BYTE  ' day
    'ALARM2 VARIABLES
        A2MINs      VAR BYTE  ' minutes
        A2hr        VAR BYTE  ' hours
        A2day       VAR BYTE  ' day
    ' Initialize Hardware
        'Set registers
          TRISA =%00000000
          TRISB =%00000000
          TRISC =%00000000
          TRISD =%00000000
          TRISE.0 = 0
          TRISE.1 = 0
          TRISE.2 = 0
          INTCON2.7 = 0
        ' Initialize Display    ' commented out during DS1337 testing
          'Pause 1000                         ' Delay to let LCD start up
          'LCDOut I,CLR:Pause 50              ' Clear Display
          'LCDOut I,Line1+2," RTC TEST "      ' Display "RTC TEST" on 1st line
          'Pause 500
          'LCDOut I,Line2+2,"..Power On.. !!" ' Display "Power on" on 2nd line
          'PAUSE 1000
        GoSub SetTimeAndDate
    ' Main Program Loop
        ' Read the current time and ALARM settings from the DS1337
            I2CRead DS_SDA, DS_SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]
            Pause 20
            I2CREAD DS_SDA, DS_SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
            Pause 20
            'I2CRead DS_SDA, DS_SCL, RTC, Alm2min,[A2MINs,A2hr,A2day] ' No Alarm2 during test
            'PAUSE 20
        ' Display Time and ALARM2 settings on the LCD display 'No LCD during test
        GoTo Main
    End     ' Insure program stops if reaches here
    ' START LIST OF SUBROUTINES
    'DisplayTest:       'Commented out during test of DS1337 code
        'LCDOut I,Line1+2," TEST "           ' Display "TEST" on 1st line
        'PAUSE 500
        'Pause 1000
        'RETURN
    SetTimeAndDate:
    ' Initialize clock variables to 0
        yr=0:date =0:mon =0:day=0:hr=0:MINs=0:sec=0
        A1sec=0:A1MINs=0:A1hr=0:A1Day=0
        A2MINs=0:A2hr=0:A2day=0
    ' The BCD constants below set the RTC to: 19:20:30 on 06-02-2008
        yr=$08
        mon=$06
        date=$02
        day=$01
        hr=$19
        MINs=$20
        sec=$30
    'Define ALARM1 FOR 19:21:00 & to alarm when hours, minutes, & secs match.
        ' This requires AIM1=AIM2=AIM3=0 and AIM4=1
        ' (A1xxx + $80 or A1xxx + 128d sets bit 7 in AIM1,A1M2,A1M3,A1M4)
        A1hr   = $19        ' for AIM1 = 0
                            'Bit6 must be 0 for 24 hour clock
        A1MINs = $21       'for AIM2 = 0
        A1sec  = $00        'for AIM3 = 0
        A1day  = $01 + $80  '$01 + $80 = $81 = 129d = $10000001 for AIM4 = 1
                            'DY/_DT Bit6 = 0 for using Day of month alarm
    'Define ALARM2 FOR 19:22:00 'Commented out during DS1337 testing of 1Hz
        'A2hr=$19
        'A2MINs=$22
        'A2day=$01          'DY/_DT Bit6 = 0 for using Day of month alarm
    'Set the main Time
        I2CWrite DS_SDA, DS_SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]
        Pause 20
    'Set the Alarm1 Time
        I2CWrite DS_SDA, DS_SCL, RTC,Alm1sec,[A1sec,A1MINs,A1hr,A1day]
        Pause 20
    'Set the Alarm2 Time   ' Alarm2 Commented out during testing
        'I2CWrite DS_SDA, DS_SCL, RTC,Alm2min,[A2MINs,A2hr,A2day,contrl]
        'Pause 20
    ' Clear STATUS and set CONTROl registers
        I2CWrite DS_SDA,DS_SCL,RTC,StatusReg,[$00] ' Clear STATUS register
        PAUSE 20
        I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[%00011001]' Starts the oscillator, sets the SQW/OUT, enables INTA
        Pause 20
    Mentor, Ohio
    Smile
    Hi Jellis,
    Try this line in place of the Cntrl you are now using:
    cntrl CON %00000101 ' sets the SQW/OUT to 1Hz pulse, logic level low
    I used a 4.7K pullup on the SQW/INTB pin then into a 1K resistor to the base
    of a PNP transistor. Then I used the transistor to drive an LED.
    Your current control register setting of %00011001 should cause the 1337 to
    output the 32Khz pulse.
    I would suggest you focus first on just getting the clock to work then add the
    SQW output then the alarm1 features.
    Unfortunately I don't have the circuit board with me that I had mine working
    on.
    Also I have a jumper on my clock board that I put through the uC so when I first powerup my clock it looks to see if the jumper is on (low) and if it is, then I go to the SetTimeand Date routine. If its high it skips over the routine.
    Did you look at the wiring I mentioned previously? Do you have 4.7K pullups on the SCL and SDA lines?
    BobK
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
