TC35i GSM With PIC 16F690 help
Results 1 to 34 of 34
    Sep 2009
    Voltages shoul be about +/-10V.
    Quote Originally Posted by financecatalyst
    First: Why have you used "0" in the instruction serout tx,0,...
    Second: why have you not used serout2 and used just serout & serin2 instead of serin?
    There no reason why i used serout.
    0 is used to set bondrate to 2400T.
    Set cursor to serout and pres F1, and everything is in help.
    Program is working. I used to check conection with modem for my call & sms controller.
    Code with status led:
    Init:
       toggle led1
       serout tx,0,["AT",13]
       serin2 rx,396,1000,init,[WAIT("OK")]
      serout TX,0,["at&f",13]
       toggle led1
      serout TX,0,["at+cmgf=1",13]
       toggle led1
      serout TX,0,["at+clip=1",13]
      led1=1
    Start:....
    Led will flash every second if modem is'n connected.
    While setting up modem led will flash every 0.5s.
    When device is ready led stay on.
    Exclamation
    Init:
       toggle led1
       toggle led1
       toggle led1
      led1=1
    Start:....
    After all day breaking my head - I have to say Many Thanks to all who have tried to help me and especially you for the code and Aratti (for hardware correction).
    It is working now.
    BUT as usual few questions to understand it better.
    1) Why is it only working with serout & serin2 combination. I tried it with serout+serin & serout2+serin2 but it didn't work in this combination.
    2)What is the actual difference between 0 & 396 when they BOTH are true baud 2400?
    Thanks again
    Sep 2009
    It should be work with serout and serout2.
    0 and 396...
    look in help in mcs!!
    396 is for serout2 and serin2
    0 is for serin, serout...
    you have tables in help...
    May 2008
    Italy
    Tray to introduce a pacing value in the SEROUT2 command. See page 140 PBP manual.
    Al.
    Exclamation New One!
    Hi Everyone
    I am now able to send text messeges. New Problem, I am unable to read an sent sms. Here is my code:
    rea:
    gosub one
    serout2 tx,baud,["AT+CMGF=1",13]
    Serin2 rx,baud,5000,rea,[WAIT("OK")]
    pause 5000
    gosub one
    serout2 tx,baud,["AT+CMGR=1",13]
    Serin2 rx,baud,5000,rea,[WAIT("REC UNREAD"),skip 3, STR num\12,skip 27,STR sms\10] 'CODE NEVER MOVES FORWARD FROM HERE
    portc=255
    pause 3000
    portc=0
    if sms[0]="t" and sms[1]="e" and sms[2]="s" and sms[3]="t" then
    goto done
    goto rea
    done:
    Serin2 rx,baud,5000,main,[WAIT("OK")]
    gosub two
    gosub two
    gosub two
    serout2 tx,baud,["AT+CMGS=",34,"+44798XXXXXXXX",34,13]
    Serin2 rx,baud,5000,main,[WAIT(">")]
    PAUSE 500
    SEROUT2 tx,baud,["done",26]
    goto rea
    Feb 2011
    Default Re: TC35i GSM With PIC 16F690 help
    hi all,
    I have read through the discussion that you guys had. They are so informative and useful. Now I want to send message to the PIC16f690 to turn on a LED. My GSM and PIC can work well with hyperterminal. However, if i want to have a direct connection from GSM to PIC, i dont get any response. Any ideas?
    char AT[]={0x41,0x54,0x2B,0x43,0x4D,0x47,0x52,0x3D,0x34,0x0 D,0x0A}; //AT+CMGR=1
    while(1)
    for (j=0;j<11;j++)
    TXREG=AT[j];
    for (i=0;i<500;i++){
    if (RCREG=='T') // if receive T then turn on LED
    PORTC=0x01;
    for (i=0;i<1000;i++){
    And did you notice that we are using BASIC ?
  1. Want to learn GSM & PIC programming
    By financecatalyst in forum GSM
    Last Post: - 25th February 2014, 09:22
  2. GSM With PIC?
    By financecatalyst in forum General
    Last Post: - 19th September 2009, 23:12
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 03:59
  4. gsm card reader using pic
    By ninebarmaximus in forum General
    Last Post: - 6th December 2005, 18:08
