TC35i GSM With PIC 16F690 help
Results 1 to 34 of 34
    Feb 2011
    Default Re: TC35i GSM With PIC 16F690 help
    hi all,
    I have read through the discussion that you guys had. They are so informative and useful. Now I want to send message to the PIC16f690 to turn on a LED. My GSM and PIC can work well with hyperterminal. However, if i want to have a direct connection from GSM to PIC, i dont get any response. Any ideas?
    char AT[]={0x41,0x54,0x2B,0x43,0x4D,0x47,0x52,0x3D,0x34,0x0 D,0x0A}; //AT+CMGR=1
    while(1)
    for (j=0;j<11;j++)
    TXREG=AT[j];
    for (i=0;i<500;i++){
    if (RCREG=='T') // if receive T then turn on LED
    PORTC=0x01;
    for (i=0;i<1000;i++){
    And did you notice that we are using BASIC ?
    Feb 2011
    Yes I knew it. Though it's BASIC but I still get some ideas from it. So do you have any ideas for C?
    After a long time, but I would like to ask here as well as you lot have worked with TC35i:
    * Are there any AT commands for this or how to see the keyed in number from the mobile keypad on the other end during an active voice call. MY TC35i is connected to my comp with RS232. I am watching and sending normal AT commands using hyperterminal.
    Currently what happens is that I dial the modem using my mobile, hyperterminal shows RING ****, I send ATA, and call gets answered and OK appears. After that when I press any number on the keypad, nothing appears on the hyperterminal.
    Hope to crack this problem here soon. Thanks
    ___________________
    WHY things get boring when they work just fine?
    May 2008
    Italy
    Numbers are encoded in the DTMF signal. If you need to read them you have to decode the dtmf sound signal. The easiest way is to use a MT8880.
    Cheers
    Al.
    Thanks Al. Though I will search on this IC now, but I am a little confused as to the connections of this IC. What I mean is I have used TX/RX lines from RS232 already, where would this DTMF IN/OUT will connect to? I have come across few circuits but this IC is connected to home phone line rather than MODEMS.
    ___________________
    May 2008
    Italy
    The DTFNM input that normally is connected to the phone line, must be connected to the voice out of your TC35i. Generally one capacitor of 100 nF and 100 Khoms in series is just enough. See the examples on the data sheet. The decoding is presented as a nibble ( 4 bits).
    Cheers
    Al.
  1. Want to learn GSM & PIC programming
    By financecatalyst in forum GSM
    Last Post: - 25th February 2014, 09:22
  2. GSM With PIC?
    By financecatalyst in forum General
    Last Post: - 19th September 2009, 23:12
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 03:59
  4. gsm card reader using pic
    By ninebarmaximus in forum General
    Last Post: - 6th December 2005, 18:08
